IvarS
Tachometer With Aftermarket Ecu
Gibbo GTI
Cant work that one out, too many wires and only one coil. What does B stand for?
Don't know what B stands for, found the pic on ignitionparts.co.uk
Can you confirm that this diagram is correct for the 2.0 mi16/S16 engine conversion with the standard 205 tacho. I left the zenner diode off as it seems others have had success without it.
thats exactly it, i've yet to try it without the zener.
Gibbo GTI
Excellent, have ordered:
348-5369 4 £0.06 £0.24
Diode,Rectifier,1N4004
199-7135 5 £0.43 £2.15
Resistor,wirewound,silicone coated,2.5W,
206-5879 1 £2.55 £2.55
PCB,single sided,prototyping,SRBP,100x16
381-5085 1 £0.85 £0.85
Enclosure,min,ABS,grey,50x35x17mm
With the horrible vat & delivery it came to just under £13, much cheaper than the converters on fleabay :)
Thanks to all who have aided in the design of this tacho signal converter :(
no worries, what's the PCB and enclosure you've got?
I stuck mine in a funky clear film canister :)
Mikey G
I wrapped Stu's in heatshrink and intergrated it into the wiring loom :)
Cant see a thing, and i'm not expecting it to breakdown either :fingerscrossed: :(
Gibbo GTI
Good idea, don't have any of them though.
The enclosure measures 50x35x17mm
The stripboard (PCB) measures 160mmx100mm
Gibbo GTI
Will be soldering this together today and fitting it to the car :)
