SimonJ
Superleggeras And Studs
SimonJ
I've got my eye on a set of OZ Superleggeras and know that the usual thing is to fit spacers and longer bolts but I'm running PTS studs/nuts supplied by Skip Brown. Does anyone know if these studs are long enough to work with the spacers or if not can you tell me the length of the bolts you use so I can work it out myself. Thanks.
Jonmurgie
Perhaps try calling Skip Brown and asking them? Though I think 85mm comes to mind... Sean had longer studs with his Supperleggeras and spacers (I have his rear ones on my beam, and they are loooooong!)
smckeown
i'm pretty sure I had to use the SBC 80mm studs.
SimonJ
Mine are about 80mm (think there was the option of 60mm or 80mm) so should be OK then. Thanks.
