Guest TSL 333
Brake Pedal Travel
Guest TSL 333
Per the topic above, any ideas? 205 1.6 GTI. :lol:
Pugnut
if everything else is as it should be , firm pedal and well bled then you're rear brake shoe adjusters are siezed.
Al
Guest TSL 333
Al
Hubs off and some WD40 then?
Pugnut
you really need to strip them off the shoes and free them up with a wire brush and wd40 until everything works smoothly . then coat in copper grease and refit , they should adjust by just prizing the shoes away from each other before you refit the drums
Guest TSL 333
Will have a look this weekend - cheers mate!! :lol:
jonah
Is the pedal travel still long when the handbrake is on? If so this means the rear adjusters are not the problem.
BTW the adjusters should move freely without needing any oil or grease... if you do put some one then it's likely to attract brake dust and clog things up.
Sam
I had this problem for ages, I solved it by fitting new rear cylinders, pedal was nice and firm and much shorter travel.
Guest TSL 333
Regarding the problem being present when the handbrake is on, I am unsure and the Pug is tucked up the back of my driveway at the moment behind my Scooby. I get paranoid moving it in the evenings unless I have to as it is 'a bit burbly' and we have neighbours with kids!!! I will check tomorrow.
Cheers guys!!!
Guest TSL 333
The problem is still apparent irrespective of where the handbrake is. That said, just did a trackday on Sunday (at knockhill) and all was very good. The brakes felt excellent all day - no fade or anything, just a slight wobble when the brakes are applied initially.
Rippthrough
OK, sounds similar to what we've been trying to sort with the 306, the linkage to the back of the master cylinder needed adjusting, as although it was meeting the master cylinder, the slack in the assembly wasn't been taken up. (There may be some slack in the pedal side too, but that's a bit of a pain to sort.)
Edited by Rippthrough
