Guest LOTRS Posted February 3, 2006 I want to change my head unit and thought it would be a quick 5 min job.... The existing head unit install is a botch job and all the cables have been cut from the connectors and only 1 used for the power (and the earth....) By a process of elimination, I think that I have worked out what each is: Light blue cable = A3R (+ accessories) White cable = B7R (battery +) Green/yellow = - earth Yellow = 212 and 212A RH speaker cable White = 211 and 211A LH speaker cable (can anyone tell me how to identify which is which, as neither has the A designation on...) Can anyone confirm that this is correct? I've got an ISO connector with bullet ends to connect the leads up properly. Can anyone also confirm that the "B7R (battery +)" cable is the same as the battery constant (yellow) lead and the "A3R (+ accessories)" is the ignition/switched (red) lead? Many thanks Share this post Link to post Share on other sites
pug_ham 242 3 Cars Posted February 3, 2006 Is this topic anyhelp? Graham. Share this post Link to post Share on other sites
Guest LOTRS Posted February 3, 2006 Is this topic anyhelp? Graham. Yes! Just what I need! Many thanks! Share this post Link to post Share on other sites
