johnrobertgordon
205 1.6 Lx Auto Specs?
johnrobertgordon
I have just been given a 12,000 mile (yep given!!!! :( ) J reg 205 1.6 LX Auto. The engine looks the same as my gti engine but with a big webber carb plonked in the middle.
My question is are there any differences to the engine, ie cam valve size ect ect. Also would the hubs and driveshafts be the same as my GTI.
Guess whos going to have an auto bonnet on their road rally car.
Any of you oldies fancy an auto box for your GTI's :)
johnrobertgordon
25 views and no reply's? surley one of you must know if the driveshafts and hubs are the same?
boombang
Simplest way may be to see if it runs Gti style wishbones or the basic control arm things - if Gti style wishbones then the shafts and hubs most likely the same!
DaveW
ah damm there was a thing about this a while back i cant remember if the engine can be used or not....
These should run a small valve XU engine producing a mere 90 ish bhp with different inlet ports due to no injection, Hub's and shafts should be as a billy basic 205 along with solid Disc's
johnrobertgordon
Yep, its got billy bog wishbones and solid disks. Could i not use the hubs and drive shafts on me 1.6 gti, i just need a quick fix as i have a rally next weekend and hardly any money left. :)
Edited by johnrobertgordon
johnrobertgordon
thanks for re naming the thread, started feeling like a bit of a gimp with it having that non descriptive title
johnrobertgordon
Will the hubs from the auto go onto my 1.6 wishbones without causing any problems like adverce camber ect. Will my vented disks fit on said hubs. Will i also be able to use the driveshafts from the auto. Please help me.................i'm impatient
KRISKARRERA
Wasn't the 205 auto carb an 80bhp engine? I know that in the 309 and 405 it was 92bhp.
johno_78
from what i remember of the auto my missus used to have, it is an xu5j engine with single carb which produces 80 bhp. i believe it is the same spec running gear as the 1.6gti so the driveshafts and hubs are the same.
hope this helps.
