allanallen
Oil Cooler On Vtr Block
allanallen
ive done a search and not had much luck :(
well i need an oil cooler on my 205 its a xs head on vtr bottom end jobbie, problem is the filter isnt the same as an xs as it has a take off so it can clear the cat (when in vtr form)
so i need to know if there is a sandwich plate for the vtr oil filter or can i take off the take off and use somethin else :)
oh and anyone know were to find info on drysumping??
respect bigup me 205 massive innit iiiiiiiiiiiiieeeeeeeeeee
Ted
i did this on my engine. i put the water - > oil cooler (from vts, rallyes) on.
you need an insert that the normal tin can filter screws into. Also you need to block off a small hole left when removing the take off thing.
i have said cooler and insert avaliable - PM me
