Rippthrough
Mintex Shims
Rippthrough
The 1144's on my car have started squeeling at low speeds, didn't get any shims whith them, but I remember someone saying they would send you a set out if you e-mailed them?
Can anyone remember who to e-mail?
pacey205
Rallydesign sent some out to me although i did buy them from them though, might be worth atry.
Michael
Rippthrough
Michael
So did I :P
Problem is they're that busy at the minute they're hard to get hold of :S
Edited by Rippthrough
DrSeuss
Give the back of the pads a blast with copper grease. Being sure to not contaminate the pad surface or the rubber seals.
Super Josh
Unfortunately the usual copper grease trick doesn't work on the 1144s. I suffered from the same problem and, either i've gone deaf( highly likely at my senior years :P ) or they've eventually bedded in. I'll be interested to hear how you get on with the shims.
Josh
Rippthrough
I've e-mail them and TDM too.
Probably didn't get the shims as according to the box the pads were made in '03! :P
C_W
I've never had problems with squealling 1144s, they are quite a soft pad anyway and I've never liked the look of using the backing pads as they look as though they'd take some brake feel away.
Rippthrough
Just given 'em some stick down a b-road, and the squealings gone. :o
Guest rick03054
Are these the things you're meaning?
If it is I have 6 and your welcome to them.
Edited by rick03054
Rippthrough
I think those are the ones, yes!
Guest rick03054
PM me your address and I'll get them in the post then. :o
Rippthrough
PM me your address and I'll get them in the post then. :D
PM'd.
IOU - 1 pint of the lands finest. :o
saveloy
If you can't get hold of the shims,you can try something from Bendix called Blue Goo,I think. You smear it on and once it sets,is similar to the backing pads.
Personally,I would forego both and cut up some 1.5/2mm stainless steel sheet and fit these behind the pads. Far more effective and you get the benefit of less heat dissipation through the calipers.
Rippthrough
There's no room for them, there's only about 2mm of space left, don't think a 1mm sheet would do much.
Went down for some tyre prices today, and the bloke told me I'd need new pads and discs as the old ones are squeeling and down to the backing plate, and he couldn't let me go back out on the road with them like that.... :D:D
Needless to say I didn't buy my tyres there after that!
Rippthrough
Arrived this morning Rick - thanks!
I gave the OAP the drink as requested, unfortunatly, that combined with competely silent brake pads mean that not only did she fall into the road, she didn't hear me coming.
On the other hand I did get her pension book before the ambulance men noticed.
