simon205Mi16
Spacers And Wide Wheels?
simon205Mi16
I am getting some wide arches to put onto my 205 over the next month or two.
But i need to fill them up so was wondering whether to put 225/40/16 tyres on and some spacers???
Is this a good idea or will it drastically effect the handling?
sonofsam
If your going the spacer route,i would use hubcentric ones,so they locate on hub and in wheel,i have a set of 25mm hubcentric ones,gimme a shout if your intersted.
some will say it causes wheel wobble at the front due to the sapcers moving the caster angle out and causing torque steer type effects
think this has been discussed lots :P
allanallen
you need hub centric to get thuogh a M.O.T so id buy these
i had 15mm spacers on 15 inch gti rims it felt sweet apart from brake shake doubled!! i had to wrestle it till the brakes cooled down
simon205Mi16
25 mm sounds a lot to me or is this ok?
How much do you want for them posted?
torque steer etc im not to bothered with as it does that at the mo anyway.
suppose ill have to see about wheel wobble.
scary about the brakes. is there anyway of getting around it?
wheel balance, tracking etc......
sonofsam
never had any problems getting through MOT with non hubcentrics,granted that was two years ago,things might of changed
Are you sure? I've never once had my wheels removed during an MOT, and it's basically impossible to tell a hubcentric spacer from a non-hubcentric spacer with the wheel still on the car. So long as the wheel is securely mounted, I can't see how or why it would fail?
sonofsam
Yes 25mm is alot,you may not need them if you have wider wheels,£90 delivered.they come with a set of 16 longer bolts for fitment of after market alloys.ie not flat seated bolts for speedlines
shouldnt get wheel wobble with hubcentrics. :P
simon205Mi16
i shall find out but 25mm will prob put them out too much.
anyone know where i could get some 10-15 mm ones?
simon205Mi16
Thanks for that mate.
Didn't realise they were that expensive its gonna cost nearly £400, each set contains 2 spacers for 1 axle!!!!!!
Ouch!!!!!!!!
simon205Mi16
Just been searching for spacers and come across this site if anyone is interested in them....
http://www.performancefx.net/wspeugeot.htm
There not just for peugeot they can get anything by the looks of it
sonofsam
Yes Delta Mics are the ones i have :P
simon205Mi16
are yours the ones which bolt to the hub then the wheels bolt to the spacer or do the wheels bolt through the spacer then into the hub?
Do you have any pics of the 25mm spacers on a 205?
sonofsam
There the ones with longer bolts,so they do not bolt directly to hub.
er yes see my sig 'Green machine' but that was with ford offset wheels
i have a pic with 25mm spacers and 7J peugeot fitment wheels will dig it out later for you
Edited by sonofsam
simon205Mi16
If you could dig them out that would be great.
Thanks a lot
allanallen
ok well they are not meant to be used on the road surley
tom_m
the MOT didn't even look at my spacers!
simon205Mi16
suppose it depends on where you take it too really whether its a really strict place which checks every last detail or whether its a friend who checks over all the major points.
tom_m
mine was the local motest, completely above board (even failed the first one with knackered driveshafts!)
Edited by tom_m
simon205Mi16
here you go mate,pictures are with a 309 beam,25mm spacers and ET18 17" x 7 wheels
http://i23.photobucket.com/albums/b393/djs...am/DVC01038.jpg
http://i23.photobucket.com/albums/b393/djs...am/DVC01037.jpg
They dont look too wide actually about what im after with the wide arches and already have the 309 beam fitted ( not lowered yet though) :P
Did you have the 4 spacers?
and how much would you accept inc postage? as i can get new ones for £90
sonofsam
Yes four spacers(hubcentric but not bolt onto hub) and 16 x 50mm(tapered seat) long bolts,im in no rush to sell them,so price is £90 delivered :)
simon205Mi16
ok mate not a prob ill see what my account is looking like when i get paid next week. and let you know..
