Kenno
Radio Wiring Help
Kenno
Hi, have looked at the wire in theradio bay no connectors but here is the wire colors
Thick: Green/Yello, Blue, Off White,
Thin Twisted with each other: Yellow & White, Red & White, Blue & White, Green & White.
I have a new ISO Block to connect but dont want to muck up.
All help would be great
Kenno
OK just incase I have done a search on the topic to no avail
kate205gti
u got a pic kenno? :)
Kenno
Left to Right Thick: Green/ Yellow, Off White, Blue, Thin: Blue & White, Red & White, Yellow & White, Green & White.
Cheers Hope that helps
timmsy19
green/yellow= ground which will go to black cable on headunit
off white = negative(i think) - yellow depending on heat unit may not be needed
blue = positive - red
not sure about thin wires i done it by trial and error. had to do both mine and my brothers cars :)
mareksio
Just wired mine up yesterday - found this topic useful for sorting out what goes where: Wiring
Marek
Kenno
yep thats its thanks all for your help sounds soon in car i hope. :)
timmsy19
good luck m8 it can be pain in the arse if they have been cut by a complete numpty
jim205GTI
mine were butchered aswell but a mate suggested using a bulb to test which wire was which by the bulb lighting up :o i just did some educated guesswork and got it right :o thankfully
