gti-hysteria
Sounds In A Cti
gti-hysteria
i had a cj which i put 6x9s in the parcel shelf but with the roof down hmmmm no sound... any1 know anywhere else i can fit rear speakers, or should i just go for good front ones????
tidypug
if your up to a bit of DIY you can get them to fit in the rear panels next to the rear seats.
gti-hysteria
Yeah im up for that but the rear windows wind down so dont think there will be room in there cause of the window mechanism.
d-9
Ditch the back seats and put in a wicked build innit
Simes
lol!
Richie
Id stick with some good front's. Or "ditch the seats and put in a wicked build innit".
Henry Yorke
What you need is some door builds in the front
There is no point putting in rears as you have discovered, unless you just turn off the fader to the rear when the roof is off
kuuner
this could be also an option for you:
gti-hysteria
lol dont think the rear passengers will be comfotible, i think front door builds will be the best option.
Guest smokinslim
Had the same dilemma myselfy. Ended up removing my glovebox and panel below steering wheel, replacing them with mdf and fitted my 6x9s there :)
