adam_young
Sound Of Mi Engine
adam_young
My wife reckons I have spent loads of money to put a washing machine engine under the bonnet. She has a point though - why does the engine whine like something out of a Metro?
Edited by adam_young
Pugnut
slacken you're timing belt!!
get it adjusted properly .
i guess it could be the alternator belt , but more likely to be the cambelt
it wont be doing you're water pump any favours
Edited by Pugnut
They definately shouldn't make an obvious whining sound, and as said above, check for an over-tensionered cambelt (as that's the exact sound they make, having done it myself first time I did an Mi cambelt :))
Sandy
If it's been overtight, there's a good chance the tensioners bearings will be mullered. I highly recommend you chnange both tensioners.
C_W
Mine whines occassionally if its quite cold but stops when its warmed up but its not someting you can hear when driving.
adam_young
So now you have me worried, but it could just be my ears. Will have to pop down the road and visit GhostCav to see what his sounds like.
205turbz
Quick ones do whine!! :D
Maxi
Id have to agree.....Ive previously had two 205 mi16s, and both of them used to whine and were bloody quick ones :D:lol: even in standard form...
Has it been whining all the time or just started too..ifso, id be worried to..... :)
Alex.....
tidypug
whats the best way to tension up the belt tho? I thought it was about right when you can turn the longest run by 90 deg, which i've done and it still wines.
Col
could maybe be a pulley?
tidypug
i hope not, i replaced them about them both when i put the engine back togather last time, did about 200 miles took head off then put it all back together again. I'll double check that i've not over tightened the belt. I've used gsf pulley's could that be the problem?
Col
worth noting that maybe next time try and use euro car parts. they are a parts dealer for citroen so theres a far better chance of getting OE parts
sorr
I would also check that it is not the alternator before going to the hassle of checking the timming belt. I have a noisey bearing on mine that makes it whine like a supercharger.
Redtop
As sorr says just take the alternator belt off for a while and listen. Would be best to try all them wee simple things out first before you jump to a big conclusion and start into the heavy stuff. If you did that then you might end up kicking yourself!
Edd-XS
just to add, my mates 106 GTi makes a whining/whistling noise... only mods are an ecosse ram air filter, and a peco back box, so what are peoples thoughts? its fecking quick, and as said, sounds like a supercharger or something! is it a similar thing?
Edd
Col
Edd
my 106 does the same wi a induction kit and decat
Alastairh
My 106 whines now :rolleyes:
Its French *shrugs shoulders*
Alastair
Edited by Alastairh
Guest davetibbs
Older Renault engines are the worst for whining!
Renault Espaces make a hell of a racket.
Pugnut
maybe its aftermarket cambelts ?
i've seen a few with different shaped teeth
nick
Mine used to whine when it got hot, I tried to re-tension the belt but it still did it.
It had new tensioners, water pump and a Gates belt. I never did get to the boTTOM OF IT.
nICK
