guffe 2 Posted January 2, 2012 (edited) On 3/25/2010 at 10:36 PM, hexhamstu said: anyone know the weight of a rear beam? 205 1.9 GTI rear beam with brakes ~56 kg 309 GTI rear beam with brakes ~57 kg weighted at courier scale including some cardboard padding. Edited January 2, 2012 by guffe Share this post Link to post Share on other sites
Anulfo 22 Posted January 4, 2012 An overall weight enquiry really.I recently saw in an old booklet i have of a guy who was selling his 'race prepped' 205gti.It was a very well put together car with Mi 16 engine,glass fibre boot and tailgate,glass replaced by plastic,stripped out interior etc,you get the picture.My main issue is that he quoted the overall weight of the car as 690kgs!!...would this be a realistic possibility? is there actually that much weight to be shed from the standard 205?? Share this post Link to post Share on other sites
Cameron 16 Posted January 4, 2012 Wow 56kg is a LOT! Share this post Link to post Share on other sites
Anulfo 22 Posted January 4, 2012 On 1/4/2012 at 3:12 PM, Cameron said: Wow 56kg is a LOT! Ugh?? Carfolio gives the weight of a standard 1.9GTi as 875kgs? 875kgs - 690kgs=185kgs.......plus the car in question had been converted to Mi 16 power plant. Share this post Link to post Share on other sites
guffe 2 Posted January 26, 2012 Weights on wish list: EW7 or 10 block (no internals) EW7 or 10 crank EW7 or 10 head (no manifolds) would be very pleased if someone could weight these for me. Share this post Link to post Share on other sites
Emmy Seize 8 Posted January 27, 2012 (edited) On 1/4/2012 at 3:36 PM, Anulfo said: Ugh?? Carfolio gives the weight of a standard 1.9GTi as 875kgs? 875kgs - 690kgs=185kgs.......plus the car in question had been converted to Mi 16 power plant. The rear beam weight in the post above......... Edited January 27, 2012 by Emmy Seize Share this post Link to post Share on other sites
Strictly_Derv 34 Posted January 27, 2012 Does anyone know the weight of a complete XUD9 TE engine with no gearbox? Share this post Link to post Share on other sites
welshpug 1,680 Posted January 28, 2012 less than an MI16 or a gti6 specifically no, never weighed one but they must be over the 100 kilo mark, given the alloy xu7 and the 8 valve xu weigh around that. Share this post Link to post Share on other sites
Strictly_Derv 34 Posted January 28, 2012 On 1/28/2012 at 1:31 AM, welshpug said: less than an MI16 or a gti6 specifically no, never weighed one but they must be over the 100 kilo mark, given the alloy xu7 and the 8 valve xu weigh around that. It's funny that because people always go on about diesels making car front end heavy and handle like crap, but this isn't always the case then Share this post Link to post Share on other sites
welshpug 1,680 Posted January 28, 2012 indeed, the gti6 is the heaviest 306 for example. Share this post Link to post Share on other sites
Daviewonder 533 3 Cars Posted January 29, 2012 Has anyone compared the weights of an XU9 8v and an XU10 8v please? Share this post Link to post Share on other sites
Anthony 1,003 Posted January 29, 2012 On 1/27/2012 at 4:51 PM, Strictly_Derv said: Does anyone know the weight of a complete XUD9 TE engine with no gearbox? Book weights for the 1.8, 1.9 and 2.1 TD engines... XUD7TE = 150kg XUD9TE = 140kg XUD11ATE = 171kg and to complete the set, the book weights for the 2.0 and 2.2 HDi... DW10TD = 150kg DW12TED4 = 182kg Share this post Link to post Share on other sites
Strictly_Derv 34 Posted February 5, 2012 How is the '9 10kg lighter?? I always thought it would be heavier! Share this post Link to post Share on other sites
welshpug 1,680 Posted February 5, 2012 thinner wall block from the larger bore you should see the gearbox for the DW12, ML6C, huuge! wont get a chance to weigh it unfortunately, as to remove it from the Expert/Dispatch/807/C8 you need to the drop the subframe, so its just sitting on the subframe separated from the engine! Share this post Link to post Share on other sites
Strictly_Derv 34 Posted February 5, 2012 On 2/5/2012 at 10:45 PM, welshpug said: thinner wall block from the larger bore you should see the gearbox for the DW12, ML6C, huuge! wont get a chance to weigh it unfortunately, as to remove it from the Expert/Dispatch/807/C8 you need to the drop the subframe, so its just sitting on the subframe separated from the engine! So that's why they chuck rods then haha. I wonder if the 7 would be a stronger lump then... Share this post Link to post Share on other sites
Daviewonder 533 3 Cars Posted February 5, 2012 Has anyone compared the weights of an XU9 8v and an XU10 8v block please? Share this post Link to post Share on other sites
Anthony 1,003 Posted February 5, 2012 On 1/29/2012 at 12:34 AM, Daviewonder said: Has anyone compared the weights of an XU9 8v and an XU10 8v please? It's not an exact comparison, but should be close enough - XU7JP (1.8i 8v alloy block) is 114kg and a XU10J2C (2.0i 8v iron block) is 140kg. (again, that's Peugeot's own book weights) On 2/5/2012 at 10:48 PM, Strictly_Derv said: So that's why they chuck rods then haha. I wonder if the 7 would be a stronger lump then... I think that was just a particular variety of 1.9TD that had a habit of chucking rods, rather than any inherent weakness in the XUD9 engine itself. DHY's from around 1997-1998 if I recall were the ones affected. Share this post Link to post Share on other sites
Anthony 1,003 Posted February 5, 2012 (edited) In fact, from the documents that I've got, here's all the book weights of the various mid-late 90's PSA engines: TU9M (954cc 8v alloy block monopoint injection) = 89kg TU1M (1124cc 8v alloy block monopoint injection) = 90kg TU3M (1360cc 8v alloy block monopoint injection) = 92kg TU3FJ2 (1360cc 8v iron block injection) = 113kg TU5JP (1587cc 8v iron block injection) = 109kg TU5J4 (1587cc 16v iron block injection) = 117kg TUD5 (1527cc 8v diesel) = 126kg XU52C (1580cc 8v alloy block carb) = 107kg XU5JP (1580cc 8v alloy block injection) = 108.5kg XU7JP (1761cc 8v alloy block injection) = 114kg XU7JP4 (1761cc 16v alloy block injection) = 125kg XU92C (1905cc 8v alloy block carb) = 115kg XU102C (1998cc 8v iron block carb) = 132kg XU10J2C (1998cc 8v iron block injection) = 140kg XU10J2TE (1998cc 8v iron block turbo) = 149kg XU10J4 (1998v 16v iron block injection aka "S16") = 160kg XU10J4TE (1998cc 16v iron block turbo aka "405 T16") = 165kg XU10J4R (1998cc 16v iron block injection) = 143kg XU10J4RS (1998cc 16v iron block injection aka "GTi-6") = 143kg XUD7TE (1769xx 8v diesel) = 150kg XUD9TE (1905cc 8v diesel) = 140kg XUD11ATE (2088cc 12v diesel) = 171kg DW10TD (1997cc 8v diesel) = 150kg DW12TED4 (2179cc 16v diesel) = 182kg EW7J4 (1749cc 16v alloy block injection) = 137.5kg EW10J4 (1997cc 16v alloy block aka "206 GTi") - 137kg EW12J4 (2230cc 16v alloy block injection) = 153kg ES9J4 (2946cc 24v V6 alloy block) = 215kg ES9J4S (2946cc 24v V6 alloy block) = 215kg A few of those will probably raise eyebrows... Edited February 6, 2012 by Anthony Share this post Link to post Share on other sites
welshpug 1,680 Posted February 5, 2012 so my zx would be under 1100 kilos given the engine is 17 lighter, plus the lighter wheels that saved 7 kilos a corner! (35 kilos total!) intrigued to know what these weights were, built up with ancillaries or just manifolds? Share this post Link to post Share on other sites
Anthony 1,003 Posted February 6, 2012 On 2/5/2012 at 11:57 PM, welshpug said: intrigued to know what these weights were, built up with ancillaries or just manifolds? I don't know is the answer - the weights are listed as "dry" but no mention of ancillaries, although they are shown in the images. I would assume that the weights do include the turbocharger and related parts at least though (where appropriate) It's the apparent 17kg difference between a S16 and GTi-6 engine that I find interesting, as I'm not sure where that amount of weight has been saved. The myth about the V6 engine being similar weight to the GTi-6 looks to have been blown out of the water though! Assuming that's accurate (and given they're official book figures there's no reason to doubt them) it's no wonder they seem to handle so badly - going by a sample of one that I've driven - when you've that much weight over the nose (plus the heavier gearbox) and further forward too. Share this post Link to post Share on other sites
Anthony 1,003 Posted February 6, 2012 (edited) On the subject of gearboxes, the book weights and maximum torque rating is listed as follows for manual and automatic gearboxes: MA (rated to 138Nm) = 31.7kg BE (rated between 210 and 250Nm) = 36.6kg ML (rated between 300 and 350Nm) = 45 - 49.3kg AL4 (rated to 200Nm) = 70kg 4HP20 (rated to 330Nm) = 88kg Edited February 6, 2012 by Anthony Share this post Link to post Share on other sites
Cameron 16 Posted February 6, 2012 Anthony, where are you getting these weights from and what do they represent - bare block or including any ancillaries? Maybe I'm being blind, but I can't see the weight for XU9J4 alloy block Mi16 in your list, would be good to compare that to te weight of a GTi6! Share this post Link to post Share on other sites
welshpug 1,680 Posted February 6, 2012 (edited) my potentially flawed logic guesstimate would be based on the following; On 2/5/2012 at 11:34 PM, Anthony said: XU92C (1905cc 8v alloy block carb) = 115kg XU102C (1998cc 8v iron block carb) = 132kg XU10J4 (1998v 16v iron block injection aka "S16") = 160kg XU10J4RS (1998cc 16v iron block injection aka "GTi-6") = 143kg difference between iron and alloy carb engine = 17 kg, difference between 8v carb head and 16v mi head, 28 kilos which can't be right as the head only weighs 24 kilos roughly 143 kilos, so there must be some ancillaries on there ! EDIT: googlefu is strong today. http://www.xu9j4.webs.com/TECHNICAL%20SPECIFICATIONS.html Quote Weights Engine weight (dry, no flywheel) 112.6kg Engine weight (dry, with flywheel) 121.6kg Engine weight (dry, with flywheel, alternator & starter) 132.7kg Edited February 6, 2012 by welshpug Share this post Link to post Share on other sites
Cameron 16 Posted February 6, 2012 Yeah I struggle to see how you could gain 28kg from an extra cam, 8 valves and a bit more aluminium! Maybe if the heads were made from iron.. Share this post Link to post Share on other sites
Anthony 1,003 Posted February 6, 2012 Come on Cameron, the answers to both of those are already there if you'd actually read what I'd written properly! On 2/6/2012 at 8:20 AM, Cameron said: Anthony, where are you getting these weights from and what do they represent - bare block or including any ancillaries? On 2/6/2012 at 12:16 AM, Anthony said: I don't know is the answer - the weights are listed as "dry" but no mention of ancillaries, although they are shown in the images. I would assume that the weights do include the turbocharger and related parts at least though (where appropriate) These are all from official PSA documentation, and about 90% of them are summarised on one document which suggests that they're comparable weights. It would make sense that they are complete with ancillaries especially with Welshpug's comparison for the XU9J4, but I have no idea why the S16 looks so heavy in comparison to other engines - although the T16 which is clearly very closely related is a similar weight once you knock off a little for the turbo, suggesting it isn't a misprint. Thinking logically it sounds 10kg odd too heavy, but there is a bit of extra weight on an S16 that isn't there on an 8v in addition to the obvious cylinder head - bulky ACAV manifold and gubbins, bulky thermostat housing, vacuum pump, comparitively weighty pistons/rods, coilpacks and cast coilpack cover, but I don't believe there's anything like enough weight there to make the difference quoted On 2/6/2012 at 8:20 AM, Cameron said: Maybe I'm being blind, but I can't see the weight for XU9J4 alloy block Mi16 in your list, would be good to compare that to te weight of a GTi6! On 2/5/2012 at 11:34 PM, Anthony said: In fact, from the documents that I've got, here's all the book weights of the various mid-late 90's PSA engines: 1.9 Mi16 was late 80's and early 90's so was out of production by the mid-late 90's when this document was made. Same reason there's no 1.6/1.9 GTi spec 8v's The other low output XU5/XU9 engines listed I'm assuming were for some export markets where cost is import and emissions are not. Share this post Link to post Share on other sites
