Bremar
Opening up fuse box
Bremar
Hi all, I have had the issue with the fuse box not allowing the horn accessory socket and rear heated screen working. Passed the MOT by using the fix mentioned on this site.
but I would like to fix it! I have the back of the fuse box but then there are 2 boards inside and it is the top board  that I think has the crack or dry solder joint.
does anyone know if they can be opened or maybe success can be had cutting out the area by the “M” multipoint socket to gain
access to the connections?
youtube vid attached
thanks Bremar
PhilNW
What is the fix you have tried ?  What makes you think its a dry joint?
Have you seen this thread ? see the internal diagram in it - there are a lot of cross connections within the fuse board on seperate layers ,
SRDT
It's a pain to open and more importantly it's unnecessary, you can reach the joint from the side with your solder wire and heat it from the outside with a good soldering iron.
There is no need to dig a hole like I did on this picture, it was only to confirm that this was the dry joint.
6lEJgPll.jpg?2
