Richie-Van-GTi
Mi16 / S16 part help
Richie-Van-GTi
Is anyone running a 2.0 16v engine with the s16 alternator setup? (PAS but no AC)
I need the length of the alternator bar hole to hole if possible (or a bar if anyone has one for sale) it's item 6 in the below image.
are you running  PAS or not?
  its just a bit of flat bar, a small kink in one end to account for the misalignment, and two holes,   very easy to make, specific length isn't too important, just make sure the belt clears.
Sorry can't help, other than to say work backwards, buy a belt and mock it up, from that work out what length the link wants to be, and make something?
I run LH & RH rose joints there. Mine has no PAS or AC.  I'll measure c/c distance later.
Edited by petert
Richie-Van-GTi
I got the measurement from a guy on Facebook, I know about the bends in it, my pla now. Is to either laser cut a piece of stainless and then bend that to shape or make a stepped Aluminium bar which is threaded on the alternator end.
Sorry thought the Op said,  alternator and PAS but no AC, with PAS pump low down.
Thanks all
I would have had to do some CArchaeology/bush whacking to measure mine :ph34r:
Mine is 130mm c/c. It doesn't matter if the pump is there or not, as the alternator bottom attaches in the same place, regardless,
Edited by petert
