Remote locking direct fit kit
Hi all
Has anyone got any experience with this plug in kit?
I'm tempted, as it looks a nice solution.
https://www.ebay.co.uk/itm/297823423600
SRDT
Seems very convenient, you just have to slide the switch if your car is wired the "wrong" way. But looking at the price for a pair of these 433hz remotes on aliexpress or a universal keyless entry kit on ebay this is clearly not cheap.
I know the basic bits to do this are not expensive, but someone has spent some time and effort making it into a nice drop in solution. That is worth paying for is my view.
So I bought this kit and fitted it yesterday.
Very easy to fit, it clips in place of the plip unit and plugs straight in.
It worked straight away, range also seems really good, not measured but at least 30m.
Not that I use this car every day, but remote lock and unlock does make such a difference.
Recommended anyway.
  • Like 4
Leslie green
Excellent , 5 of these have sold now so you are not the only one Tom.I'm not sure my pins on my plug are any good as there was corrosion on the plip unit pins and they are very fine. Have you fused the permanent live incase you get a short ?
SRDT
I wonder if you could replace the remote with one with a NE72 key blade from Aliexpress. They are both 433MHz but the receiver may not be compatible.
Anyone has a 206 remote to check if the receiver can learn the signal?
I haven't yet, but it is in my mind of something that would be a good idea. I unplugged and removed the old Plip board years ago after hearing of cars setting on fire when water got into that area. I haven't looked yet, but the wiring must go down the a pillar and emerge near the fuse board, so I will look to fit a fuse down there.
ALEX
edit: didn't realise this was a direct replacement for existing 205 CL system that uses radio instead of IR.  Very neat solution!
i use my Toad alarm Ai606.
Car didn't come with CL as standard so i had to buy some inexpensive solenoids for the doors.
Works really well. was quite easy to fit. edit : just checked and Toad Ai606 is no longer available new anymore, so this info is probably useless to you!
There must be modern alternatives available for those without CL as standard.. Clifford still do an analoge option, it may be an option if it outputs a pulse signal for the CL solenoid like the Toad one does.
Edited by ALEX
chris 417 mi
well i've just ordered one of these from ebay ! at the moment its £95 plus shipping etc !
Leslie green
Snap ! 2 mugs caught today lol
  • Haha 1
Well I wish I was on commission now!!
I told some friends with a white 1.9 I look after for them about it, they have ordered one too!
  • Haha 1
Leslie green
Seller having a good run now after a slow start :D id have been annoyed if I paid full price last week and it discounted a lot now
Edited by Leslie green
I think they will only work in a post 1990 car, pre 1990 had key in the door central locking rather than keyless.
hence the difference in the locking motors between pre and post 1990 cars.
Yeah thanks :lol:
  • Haha 1
