Gavin Waddell
Prepping engine bay for paint.
Gavin Waddell
I am in  the process of prepping  the engine bay for a respray as it was getting  a bit tatty and wanted to freshen it up as I  am also putting a 1.9 (cars originally a 1.6).
I have some experience with painting and prep but mainly on sailing boats ( imoca 60s, americas cup boats and a few other interesting projects).
I have sanded the bay,  I haven't taken it back to bare metal. I have welded a few holes that I had drilled previously and treated some surface rust.
I am now at the stage of going to lay down some primer, this is where I am a bit unsure of how to proceed.
I was originally going to epoxy the whole bay then filler primer on top and then top coat? As the original paint isn't that bad and the the car is a 91 plate so it was galvanised at the factory.
Or should I just epoxy the spots that  have bare metalt showing and then filler primer?
I know that I can do a wet on wet with the epoxy and filler primer that way it cuts out a sanding step.
What do you guys think?
Thanks Gavin
Unless you have all the safety gear, I would leave the 2K stuff to a pro. It's just not worth the risk.
To answer your question, don't mix. Start with 2K, finish with 2K.
Edited by petert
Gavin Waddell
I have all the safety gear sperm suits and the adequate safety mask and filters( i work in the composites industry).
The reason for wanting to use epoxy is it's protective quality on the bare metal.
Leslie green
Id epoxy the whole bay as a barrier against rust , then fill any bits you need to,  then primer and topcoat .
