mmt
Leak
mmt
Hi guys
Original cooling hose on gti6 is leaking. slowly dripping away when engine is turned off. Nothing when running. Will a bit of RTV on the rubber sealing ring do the trick?
any ideas are welcome
thanks
which hose?
mmt
Top hose from thermostat house to top of radiator.
shouldn't need any sealant, if its a push over and Jubilee clip joint then disassemble and clean, reassemble with a fresh clip if required.
or if its a O ring on a metal spigot secured by a wire clip,  fit a new seal.
mmt
Thanks.
new seal inbound.
