hoodygoodwood
Mi16 - XU9J4 - engine rebuild to go into a 309
SRDT
It looks like you could just drill the rivets heads on a 16v coil and bolt the bracket on a 8v coil.
hoodygoodwood
Thanks , i just wanted to be sure . When i bought the couple of Mi's last year they came with the usual assortment of dodgy looking old bits , 2 of the coils had the riveted on bracket but one was held on by 4 very long bolts , i took the bracket off ( which was in 2 pieces ) and got it replated along with all the other bits recently . I managed to find a new in box Bosch coil which takes the brackets nicely and is fitted in the photo although it looks like a more recently manufactured 'made in China' item . I thought i would shorten the bolts while i was at it as 2 inches long looked ridiculous . I have been looking into throttle cable brackets and possible cable routes and there are a number of options , the little bracket and rubber bush that came with this engine i have refitted for now but i will be experimenting to see what works best once the engine and box are in .
hoodygoodwood
The 405 that donated this engine had a fuel pressure damper in the fuel line which i have seen in other 405 engine bay pics , i cannot remember seeing this fitted to a 309GTI16 , does it ever cause problems deleting the damper ?
SRDT
There is some kind of damper on the 309 fuel pump itself.
I have run a number of 205 Mi over the years and never had one of those fitted. No issue.
Duroc
We've deleted it in all 205 1.9 mi16 conversions, so doesn't seem to be a problem
hoodygoodwood
Progress has been slow on the Mi swap but have removed the 1.9 GTI engine and box , its an opportunity to smarten up the engine bay and get some of the other parts ready so i have fitted a new Febi bush to the lower mount . I might be fitting the finished short engine and the original gearbox back in soon and use a bare head for now so i can start trying to mock up some sort of exhaust and get the 405 Mi16 loom trial fitted , will be asking a few questions about the loom now i have got it stripped back to the bare essentials .
