mmt 15 Posted October 3, 2024 Hi Guys What are the benefit of having a solid gearbox Mount? is it worth while. ? the car has solid engine mounts top and bottom however the gearbox must flex on its oe mount. Thought it would be better to have solid mounts all round. any thoughts appreciated thanks Share this post Link to post Share on other sites
jord294 97 Posted October 3, 2024 Personally, I'd recommend oe top and gearbox mount with bbm fast road lower bush with top mount buffers skimmed. Keeps the engine from excess movement Share this post Link to post Share on other sites
petert 641 Posted October 5, 2024 What do you mean by solid? Share this post Link to post Share on other sites
mmt 15 Posted October 5, 2024 8 hours ago, petert said: What do you mean by solid? Weld a bracket out of steel. Share this post Link to post Share on other sites
petert 641 Posted October 5, 2024 So you have zero rubber on top or bottom mounts? Share this post Link to post Share on other sites
mmt 15 Posted October 5, 2024 14 minutes ago, petert said: So you have zero rubber on top or bottom mounts? No- both engine mounts are made of a block of hard fiber. Gearbox Mount is oe. Wanted to eliminate movement completly. Share this post Link to post Share on other sites
petert 641 Posted October 5, 2024 I use the Vibra-Technics gearbox competition mount. The solution from Satchell looks better. Share this post Link to post Share on other sites
mmt 15 Posted October 5, 2024 11 minutes ago, petert said: I use the Vibra-Technics gearbox competition mount. The solution from Satchell looks better. PB in your inbox :-) Share this post Link to post Share on other sites
Spesh 35 1 Cars Posted October 5, 2024 I just changed from a BakerBM to a vibratecnics top mount and i'm impressed with it to be honest, might well change the others Share this post Link to post Share on other sites
