205freak
3D drawing xu engine
205freak
Hi, I would like to know where can I source a 3d drawing of the XU5/7/9 engine, to be able to make a new engine block with the iron liners cast in place as sleeve.
SRDT
That's a lot of work to make something close to the EW engine block.
Your best option is probably a 3D scan, this engine was made before CAD so even PSA 3D models are probably good mock-ups but not 1:1 digital replicas. There was no need for that with the tooling already up and running.
Pay someone to digitize the one you have. That will be the most accurate and quickest way.
Mm xu9 2000
This is a 2000cc carburetor xu9 engine, but I don't know which model it is. Please tell me the full name of the engine, thanks.
205freak
Ok Will do and hope to be able to manufacture it cost wise.
205freak
This might be 1.6 engine or depending on the country could BE a 1.9 but very are.
Mm xu9 2000
The engine is 1.9 with Solux carburetor, I can't find the exact model of this engine, which model is xu9, this car is in Iran.
DamirGTI
XU92C , D2A
SRDT
They are plenty of XU92C : D2A, D2B, D2C, D2D, D2H, D5A.
Check the plate on the block.
