Spesh
Drive flanges
Spesh
Need to change my front drive flanges over winter (crappy threads).
I think the part number for 1.9 non abs hubs is 330785, could someone confirm?
I see loads listed on autodoc etc, is there any brand to go for or avoid?
jord294
Correct number
Febi
Spesh
just to update.  I ordered febi flanges off autodoc
https://www.autodoc.co.uk/febi-bilstein/1871896
The taper in the cone was incorrect and didnt allow the bearings to clamp up correctly.  Not a driveshaft issue as I'm using original shafts and the issue was not apparent on the original flanges.  Was not a massive issue, quick touch with the die grinder sorted it.
jord294
Bad batch then. Had no issue with mine. Also got meyle and another brand off of mph automotive
Spesh
yup, seems to be a repeating theme these days :(
