Gohn
Valve Clearance Check Interval
Gohn
its getting up around 20,000 kms since I refurbed my XUD7TD cylinder head
everythings going good but I couldn't find any specific intervals suggested in the book to check the valve clearances
should I be checking them every 10, 20 or 50,000km or do you wait until it sounds like it needs it ?
thanks
I think every 200 000km is enough.
the wording from the Haynes manual is ' Checking should not need to be a routine operation'      'it should only be necessary when the valve gear becomes noisy, after engine overhaul, or when trying to trace cause of power loss'
so yeah, leave it alone!
given the amount of work required to adjust them, especially on a diesel, I wouldn't bother checking them until a belt change interval,   which is 72k miles or 120k km, or 5 years.
good oil and frequent changes will make them last longer, keeping the carbon levels in the oil down.
Gohn
200,000 or 5yrs ! good news then I wont touch it!
yeah as its a diesel I do my oil and filter changes at 7,500k
and I've just put on a new tbelt already so about 3yrs for the next one
thanks much appreciated
