Andyajg 0 Posted April 3, 2021 Hi,I'm restoring a 205 Open 1.4 and have had a few earthing issues all NSF. The washer jet, indicator and main beam all wouldn't work, I've run separate earth wires from each and they all work fine but obviously I must have an earth issue and was looking for pointers as to where the problem might lie,I would rather sort than run the separate earth wires. The only earth wires I can see in the engine bay on that side are from the battery and what looks like a wire from the loom to the same earth as the battery wire. Any advice would be great. Thanks Andy. Share this post Link to post Share on other sites
Ozymandis 104 Posted April 3, 2021 On the front panel uprights there are 2 earth commoning points, they are held onto captive m6 studs by a flanged nut, they are in little elasticated bags a bit like a tiny shower cap it is usually these that are manky. They are the same part as inside the boot left hand side, if You end up looking for better ones. Share this post Link to post Share on other sites
Joecar 2 1 Cars Posted April 3, 2021 Hi Andy, I also have issues with my earth so here's the earth points I know of that you might want to check; your car may not have all of them. 1) Battery to gearbox/engine block 2) Battery to chassis somewhere around distributor 3) Battery to steering column 4) Left and right side next to the radiator (the ones Jay mentioned; these tend to get corroded badly) 5) Behind the window washer fluid reservoir (I didn't know about that one until yesterday either) 6) Behind rear left light Check for corrosion and clean all surfaces, if corrosion is too much you might want to re-do the whole earth point. Good luck! 1 Share this post Link to post Share on other sites
Andyajg 0 Posted April 3, 2021 Thanks Guys, I'll check them all out tomorrow,much appreciated. Share this post Link to post Share on other sites
