Gohn
Fuel Guage Not Working
Gohn
evenin !
electrics, bloody electrics
my fuel guage is dead brown bread
I have plenty of fuel in the tank, and the needle is showing empty
I have already changed the Fuel Tank Level Sender Unit
when I turn on the ignition to the first mark, there is no movement at all from the dash fuel guage needle
have read thru many past posts to try and get a lead on what is wrong
the sender unit in the tank has a 3 pin plug with (obviously) 3 wires:
Blue 65 : Fuel Guage power wire
White 65A: Low Fuel Warning Lamp wire
Green/Yellow M66: Earth wire
the wiring diagram shows the 65 and 65A wires go direct from tank sender unit to the dash binicle
and the earth runs straight to the LR earth cluster
so far I checked the Left Rear earth cluster which is like new
checked for continuity of the M66 earth wire and its good
checked the fuse in the fusebox (No.2 , 25A) and its fine
with ignition on:
using the female loom plug at the tank, I completed the circuit by connecting a small wire from 65 to M66Earth - no movement on the dash Fuel Guage needle
same but connecting 65A to M66 with the wire - straight away my Low Fuel Warning Lamp came on the dash
Im already on my second Fuel Tank Level sender unit, as I took out the whole original tank and replaced it
the current tank's sender unit was working well previously before being put into the current car
is it possible to remove and fix a dicky Level Sender unit ?
and is there a tool to remove the screw in sender unit ? rather not bash on the tabs with a drift until they break off ..
cheers for any suggestions
Gohn
update, got the fuel level sender unit out of the tank
used a piece of PECS pipe and a small hammer to tap on the tabs of the screw-in black ring, WD40 and outsies
its black ring, level sender unit, then between that and the tank is a rubber sealing ring with 3 ridges
the sender unit is JAEGER
seems to be crimp sealed, 3 crimps around the top of the ally tube fixing it to the plastic top/3 pin plug
feels like a float slides up and down with the fuel level which enters the tube via a small hole in the bottom
the unit part number is #152796 but no longer available from Peug
so wondering if any tinkerers have ever drilled out the 3 crimps, taken off the ally tube and tried to fix the resister inside somehow ?
Ozymandis
Good morning, I have had the relavent multiplug not quite pushed home in the instrument panel on more than one occassion, I think its the top left hand plug.
If Your completing the circuit at the sender`s plug and the gauge doesnt move it isnt the sender unit at fault.
I have fixed a few senders, theres more than one manufacturer,  they were the type with a circlip at the bottom of the alloy tube holding them all together, they have a big bronze alloy coil like a slinky spring inside, it eventually snaps where its anchored at the top, its an easy fix if You can solder I have done it at the side of the road with a plumbers equipment on one occassion. Not sure whats inside a crimped one, probably a similar idea.
Edited by Ozymandis
Gohn
thanks jay,
I've just got the other one out of the tank
this ones a Veglia and as you describe,
haven't had the bottom circlip off yet because I doubt its the sender
I have now tried both level sender units plugged in with ignition on
tilt the unit up, tilt down, needle on the dash just wont budge a bit
glad to hear you reckon its not the sender unit cause I was thinkin it would be too unlucky to have 2 dudd units in a row
checked the top left binicle plug already, it looks pretty snug but took it off/on to see if that made a difference
nothin though
also, I thought it could have been the loom was being crushed/earthing between tank and body but it looks fine too
could it be the cluster ?
i've had them off/apart a few times before but where do look for a fault ?
Gohn
with ignition on:
just tested the power from the dash to the female level sender unit plug at the tank
I get 12volts for the low fuel level warning light (wire 65A)
and 6volts for the fuel guage (wire 65)
could you explain this ? I dont understand
is the maximum resistance in an EMPTY or FULL sender unit ?
thanks again
Ozymandis
Empty is max resistance,  so not a lot of juice gets to the gauge,and it doesn't move very far up the scale.
Whereas if you short the plug terminals a lot of juice gets to the gauge and if gives full scale deflection of the needle.
Check the earth wire for continuity to the plug, i think its other end is in the rear wing earth block.
6V isn't right I`d investigate that after the earth wire.
i just drank a bottle of vino with my dinner so its all a bit hazy recollection at the mo.
Gohn
thanks jay, best not get in one of your fleet of 205's just now then,
I've already checked the earth, the plug to the level sender, the plug to the cluster, the loom wires (n evry feckin other thing)
so, I took out the cluster/binicle and put in another one
connected all the plugs at the back of the cluster
 again, went to the tank and got the female level sender plug
put a wire across from Fuel Guage Blue65 to M66Earth to complete the fuel guage circuit with zero resistance
BINGO, the fuel guage needle goes to FULL !!
I have officially got a f***ed cluster, or what I prefer to call a Cluster f***
also proves your "Empty is Max Resistance"
spose Im gunna have to take the cluster apart, see if I can find the bad connection or whatever it is
Gohn
put the fuel level sender all back in tank, took out my cluster for inspection and ...found the cause of my CLUSTER FECK
a lizard had got into the cluster (probly thru one of the obsolete bulb holes) and made a bit of a mess, and laid a frikkin egg
so the extra moisture has corroded the fuel needle somewhat, (you can see it on the back of the right one)
dont know yet if the needle's siezed or the corrosion has effected the copper resistor thing that is at the back of the needle facia
had a spare cluster so have just unbolted and lifted out the dud fuel needle panel and put in the replacement one
once the clear plastic panel is off the cluster, to get the fuel panel off its two screws at the front (M5 spanner)
and three nuts at the back (M5.5 spanner), which each have a little ally washer for contacting the circuit sheet
put it all back together and slotted in and boom, needle reading just below half
crikey
Ozymandis
WTF, thats a new one on me!
We dont get many reptiles in Yorkshire apart from the odd smarmy politician from down South.
It must be the time of year, our turtle laid a clutch of eggs last week.
Gohn
just pleased its all working good
well, cept for the tacho
diesels and tachos dont get along real well
got a new part to try though, so here goes again for the umpteenth time
Robbiedundy
Posted (edited)
Hello, handy info in this thread. I have a slightly different issue - my fuel car runs out of diesel at just below half a tank shown on the gauge. Would that be faulty or wrong sender unit?
Edited by Robbiedundy
can't be the wrong sender as they are all the same, so its probably faulty.
Robbiedundy
I read ph1 & ph2 senders are different, is that incorrect?
DamirGTI
Posted (edited)
Correct !
And if you put Ph2 sender in Ph1 tank you end up with about plus half amont difference , being incorrect aka false measure of course .
Must be matched set tank + sender .
Ph2 sender :
Edited by DamirGTI
1527 96 for pre and post 1990, also no change in instrument cluster.
so I can't see why you think they are different,   if they were different there would be a different instrument cluster and part number!
DamirGTI
Well , no idea about part No's , its been a while since i've been playing with fuel senders ..
The Ph1 style sender has kinda alu. colour body and black plastic bits on the bottom and center rod over which the float slides can be seen as well with the metal kinda ring clip ... And this one you can open up and clean adjust repar etc.
Its the sender on the first few pics of this topic .
The Ph2 style , is the one i posted above - take a look at the bottom of the sender and compare the two ..
I remember once i tried to fit the above Ph2 sender inside Ph1 tank , and it over read aprox double the amount of fuel in the tank .
I even tried to fit Ph2 clusters but if i remember it was the same aka no difference it was still reading incorrect .
