boldy205
BE3 arm functions
rallyman1
Thanks Welshpug,so where is reverse on that box and do you lift or push the stick down to get over into reverse?,, thanks
opposite 5th, no detent, just shove it straight in.
rallyman1
Thanks Welshpug,tomorrow morning I am going to check linkage lengths and see what happens,,when you say opposie 5th,I presume you mean where 6th would be?,, thankyou
rallyman1
Guys,I cant thank you enough for all your help, but I have just confirmed that reverse is opposite 5th gear,making it a BE3 box?,,only confusion is that it has the two drain plugs which I thought was  the later BE1 box,but,I am confident it is the BE3,,to fill with oil do I fill through the breather/reverse cable hole till it starts coming out the level plug below?,,thankyou again,,
SRDT
To refill the gearbox I'm using a 500ml oil suction syringe on the level hole but yes you can use the breather hole if you want.
rallyman1
Thanks SRDT,glad to have all the mystery solved,on getting brakes bled tomorrow,almost completed project now,,thanks for all help,,
2 drains??   only one, on the diff casing.
level plug is on the end casing, I fill it uo through the breather at the top.
rallyman1
Thanks Welshpug,cheers
