TaffyTim 6 Posted December 30, 2003 Hello, I have my MOT soon and my discs are close to thier min thickness so i think i might need to buy some new one. Should I just go for standard ones or is it worth buying better ones? I dont use the car for track days or anything like that i just use it to zoom myself arround my town. Thanks for any reconmendations. Share this post Link to post Share on other sites
[CJ] 0 Posted December 31, 2003 Hi, Depends.. If you never experienced fading while braking or felt that your brakes changed charateristics during driving normal discs will be fine for you. Its always a good thing to change the pads as well as theses can be a bit uneven and damage your brand new discs. /Christian Share this post Link to post Share on other sites
Ahl 4 Posted December 31, 2003 I agree with [CJ]. If you do a search on brake discs you'll find a lot of brake disc theory in this forum along the same lines. 60 hole drilled and 100 grooved £120 discs are the forte of max power boys who think the reduction in surface area and brake-pad destroying ability makes them stop faster! Share this post Link to post Share on other sites
C_W 3 1 Cars Posted December 31, 2003 Get some decent plain discs with decent pads and they will be fine if not better than "performance" discs. Share this post Link to post Share on other sites
Guest jonnie205 Posted December 31, 2003 had a set of ebc turbogroove on my 306 and warped straight away and pads wore out in 3 months, a set of drilled and grooved disks will provide better stopping power in most cases Share this post Link to post Share on other sites
Gaz 0 Posted December 31, 2003 Drilled and grooved are good for their cooling effect thus reducing brake fade during heavy and prolonged braking but as for stopping power, a standard disc of the same diameter should be better due to a greater pad to disc surface area. Gaz Share this post Link to post Share on other sites
jj205 4 Posted December 31, 2003 (edited) hi mate, i bought four new ones from GSF yesterday for my 1.9, they were 14.50 each, even though the front are vented and the back ones are smaller and not vented, What car have you got 1.6 or 1.9, are you just doing front discs, If your not doing trackdays and lots of hard braking id stay with standard ones, well thats what i think, and they seem good value for money from GSF. After getting prices from motorfactors and PUG, I just hope ive got the right pads and discs, im going to fit tommorro, my cars brakes look like the one used in the haynes manual, so Girling on the front and bendix on the rear, But both sets of my brake disks came in bendix boxes, so i persume they are the same as peugeot used. Are your flexi hoses okay as well, there not much either, well if the origional hoses have been on since new they are probably all cracked if you look carefully, its better to be safe and sorry, Good lucjk with it Jonathan Edited December 31, 2003 by jj205 Share this post Link to post Share on other sites
pug_ham 245 3 Cars Posted December 31, 2003 Try getting a pair of ATE Powerdiscs from ecp they are well recommended & don't cost much more than standard discs. I have some on my pug with braided front hoses & standard Bendix pads, they work ace & I'm wondering f I want to do the 266mm upgrade before I fit the 1900 motor soon. Graham. Share this post Link to post Share on other sites
C_W 3 1 Cars Posted December 31, 2003 had a set of ebc turbogroove on my 306 and warped straight away and pads wore out in 3 months, a set of drilled and grooved disks will provide better stopping power in most cases Are turbogroove discs with grooves and those dimple holes? The only case for drilled and grooved discs is at the other end of the heat scale when you need to stop fade but it's a compromise because you're reducing the disc surface and the strength of it. Cross Drilled discs crack too, well any that you can buy to replace a standard 205 disc will. Get some Group N plain discs and decent pads like Mintex 1144 and they'll be fine. hi mate, i bought four new ones from GSF yesterday for my 1.9, they were 14.50 each, even though the front are vented and the back ones are smaller and not vented, What car have you got 1.6 or 1.9, are you just doing front discs, I just hope ive got the right pads and discs, im going to fit tommorro, my cars brakes look like the one used in the haynes manual, so Girling on the front and bendix on the rear, But both sets of my brake disks came in bendix boxes, so i persume they are the same as peugeot used. Are your flexi hoses okay as well, there not much either, well if the origional hoses have been on since new they are probably all cracked if you look carefully, its better to be safe and sorry, Good lucjk with it Jonathan The rear discs should be the same diameter (247mm), just not vented as they don't get hot enough. I wouldn't worry too much about what box they came is as Bendix are OE spec and make discs for all cars no matter what the caliper might be thats clamping it (same thing with pads). Share this post Link to post Share on other sites
Guest mbl Posted January 1, 2004 As above, standard discs will probably be fine. If you want an upgrade try ATE Powerdiscs as Pugtorque suggested. Pugtorque; I don't think you'll notice much difference going up from 247 to 266mm. With Powerdiscs, braided hoses & a good set of pads (1144's, etc) you should be fine. This is my set up with an Mi16. Mark. Share this post Link to post Share on other sites
Deadliest Pug 0 Posted January 1, 2004 I got pattern Tarox discs for my 405, they warped and then started to crack A second set of grooved ones bought through Ecosse, warped bad enough for mne to junk them after about 5000 miles Standard Pug discs from Pug, pads aswell, were going strong for about a year and 20,000 miles but did fade after a long hard drive. I say standard Pug, seemed the best on my 405. Dave! Share this post Link to post Share on other sites
Guest Super Josh Posted January 1, 2004 Go to GSF(Andyspares) and get some plain Brembo Discs. Not much more expensive than their no-name discs and are made out of decent material. Josh Share this post Link to post Share on other sites
Guest BW205 Posted January 2, 2004 How does Grp N disc differ to normal Pug Discs?? Are they better material and quality but same design Cheers Billy Share this post Link to post Share on other sites
Guest puggti Posted January 2, 2004 Ive got 12 groove and they do the job nicely compared to the standard discs i had before! Share this post Link to post Share on other sites
stevemi16 0 Posted January 3, 2004 Brembo Discs with Mintex 1144 Pads work well. Steve Share this post Link to post Share on other sites
perfecto pug 0 Posted January 4, 2004 Pugtorque; I don't think you'll notice much difference going up from 247 to 266mm. as tesco say - every little helps the 266mm disks on my bro's stdt are superb Share this post Link to post Share on other sites
Guest seb Posted January 4, 2004 I agree with [CJ]. If you do a search on brake discs you'll find a lot of brake disc theory in this forum along the same lines. 60 hole drilled and 100 grooved £120 discs are the forte of max power boys who think the reduction in surface area and brake-pad destroying ability makes them stop faster! Hmmm, those grooves do have a purpose you know, sure they remove a small amount of contact area and wears pads faster, but they prevent them glazing, which if you're braking long and hard is a good thing, no? I quite fancy getting some red.dot 20-groove (non-drilled) discs, am i to take it that these wouldn't be recommended? Share this post Link to post Share on other sites
Edp 67 3 Cars Posted January 4, 2004 I changed for ATE powerdiscs and they seem to be doing a good job plus like pugtorque said they dont cost an awful lot more than the standard discs. I have found because of the groove the wheels dont seem to collect as much dust as before which is a good thing. Share this post Link to post Share on other sites
Ahl 4 Posted January 5, 2004 Hmmm, those grooves do have a purpose you know, sure they remove a small amount of contact area and wears pads faster, but they prevent them glazing, which if you're braking long and hard is a good thing, no? I quite fancy getting some red.dot 20-groove (non-drilled) discs, am i to take it that these wouldn't be recommended? Perhaps, but 205's probably won't suffer from pad glazing unless the pads are crap or its being driven on the track. Some people spend over £100 on a pair of fancy standard size discs when it may be possible to get an entire 306 gti-6 brake setup for the same price - offering far superior braking regardless of the discs used. Ive heard good things about the ati discs, and as a non-performance brake component manufacturer, I'd be inclined to think their powerdiscs were good and do what they say they do. I haven't heard good things about red dot though - I remember hearing that their name is intentionally similar to Tar Ox with the dot and all and that they were more a max power type company, but im not certain. Share this post Link to post Share on other sites
mrswampy 0 Posted January 5, 2004 ive got ate power disks and greenstuff pads on my s16 and they are spot on. havent suffered any of the juddering that greenstuff are said to cause and ive given them some right stick. got a set of standered brembo disks and red dot pds o fit to the back tomorrow along with a new caliper so that should get ri of the judder i get from the back due to the warped disk Share this post Link to post Share on other sites
Guest h8lst Posted January 9, 2004 I studied part of an automation engineering course at BTEC level (comparable to A level) and although I didn't finish it I did cover braking systems, and I did get 95% commendation. My understanding of performance brakes (from a text book case not real world) are: Drilled disks dissipate heat much better than mere vented alone, and as posted will only help if you are using your brakes to a level at which they are starting to fade. Grooved disks on the other hand will deglaze a pad, and are very efficient at ensuring the contact area of the pad is in the best possible condition to (effectively) grip the pad. Pads glaze through heat, and not being run-in properly, apparently you shouldnt let new pads get too hot for the first couple of hundred miles. Changing your pads can have an excellent effect, and increase stopping power - although with the increased stopping power you will have increased heat coming from the disk/pad (the energy has to go somewhere). To ensure you will continue to have increased stopping power without fade you are more likely to need to have drilled disks to lose the heat. Also competition level pads are more likely to need deglazing i.e. the need for grooves. Poor condition brake fluid can often cause fade - when brake fluid deteriorates the boiling temp reduces. This leads to the brake fluid boiling close to the piston and a massive reduction in stopping power. Braided hoses as far as I'm aware increase feel rather than stopping power, but I don't know too much about that. My course teacher would have been proud! - Except I dropped out.. Share this post Link to post Share on other sites
Adi 0 Posted January 9, 2004 Drilled disks dissipate heat much better than mere vented alone How many drilled discs do you see within any motorsport series??? 2 facts about drilled discs.......1.they are prone to cracking. 2 On cars like Porsche where they are most seen at a production level......the drilled holes are there to reduce weight more than an escape for brake gasses. apparently you shouldnt let new pads get too hot for the first couple of hundred miles. Quite a few pad manafacturers instructions when bedding pads in are: take the pads thru one complete heat cycle, gradually building the heat and pressure up. The best way I have ever bedded a set of pads in was building the pressure heat up within the first 10-15 mins of driving. When the pads started to fade....I slowed down and stopped till the brakes had cooled completely. They were then ready for hard use. For many previous times of bedding pads in......I had driven easily for a few hundred miles. This included a set of Mintex 1144. They never seemed to bed in properly.....and faded really easily. The next set.....I used the first method.......and they were biting well from after 30mins of first use. Share this post Link to post Share on other sites
cybernck 424 1 Cars Posted January 10, 2004 How many drilled discs do you see within any motorsport series??? BMW E30 touring car: drilled discs: it's got cracks going from holes though . but adi's right, most (if not all) newer race cars have have only grooved discs. but not something as extreme and as efficient as red*dot 40-grooves discs . Share this post Link to post Share on other sites
