Gohn 73 Posted November 16, 2020 er this is, or was, the little horn earth from behind the LeftFront headlight runs from underneath the LF earth cluster to the horn just noticed it as I was bolting on front bumper ive made up a replacement to put in but if I dont know how I did it I may just do it again none of the other earth wires in the cluster are effected at all and I ran a lights/indicators check and they're all good the horn does not sound so once I put the new earth in I'll check its operating normally again too its not the little Fiamm black horn but a red double bunger horn with some kind of vacuum can put on by an earlier owner. not sure if that's aftermarket and ive never heard it make a peep yet suspected causes are it got fried when the welder was putting my relocated brake brackets onto the wheelarch ? or when I shorted the stop solenoid line at first startup ? either way its recent cause I just gave both LF and RF earth clusters a good cleanup suggestions from anyone with more confidence in the area appreciated, and reassurance that I'm not gunna somehow find a way to fry the whole bloody loom next time.. Share this post Link to post Share on other sites
Ozymandis 104 Posted November 16, 2020 That is exclusively for earthing the horn/horns. I`d be wary of any added Carlos Fandango horns that weren't original fitment. Share this post Link to post Share on other sites
Gohn 73 Posted November 16, 2020 thanks jay put the new earth line in and bingo ! it works great but its more powerful than the other little 205 ones so will be used sparingly whoever put it in wired its own relay to it and the separate cannister is maybe an air pump ? with two clear hoses one to each horn? its like a chorus with one higher, one lower note . the ABBA of horns could it be original spec from a GTi ? the car was Si converted to a 1.6GTi somewhere in the past with bits added ive got an original spare but I had to spend hours with the bracket on the current one to make sure it all fits in the cavity neatly so I'd rather not start cutting wires unless it has problems still no idea how I managed to burn out that earth Share this post Link to post Share on other sites
