jimbojim 0 Posted July 31, 2020 what will cause my car to wonder off line on acceleration and lift of,car is 205 gti mi16 1.6 gear box and Quaife LSD ATB looked briefly at the suspension and there is nothing really wrong with it, anyone that can shed a light on the problem will be much appreciated thank you just added few pic of ITB conversion Share this post Link to post Share on other sites
welshpug 1,722 Posted July 31, 2020 wishbone bushes or balljoint. Share this post Link to post Share on other sites
welshpug 1,722 Posted July 31, 2020 or ovalled balljoint hole in the hub. Share this post Link to post Share on other sites
dcc 855 Posted July 31, 2020 or a binding brake caliper, or flat tyre 1 side, or toe in / out Share this post Link to post Share on other sites
jimbojim 0 Posted July 31, 2020 Tire pressure is fine no play in the wish bone no break binding or the ball joint issue it isn't just a small amount of weaving and wandering it's kind of aggressive Just about keep it straight with steady right foot Share this post Link to post Share on other sites
welshpug 1,722 Posted August 1, 2020 how old is the quaife? Share this post Link to post Share on other sites
jimbojim 0 Posted August 1, 2020 pretty old the car is in my ownership more then 15yr so longer then that Share this post Link to post Share on other sites
Tom Fenton 1,633 Posted August 1, 2020 Wishbone bushes, they can look ok and still do this. 1 Share this post Link to post Share on other sites
jimbojim 0 Posted August 1, 2020 fair point will look in to it in detail hope to find something wrong Share this post Link to post Share on other sites
Tom Fenton 1,633 Posted August 1, 2020 Usually the front (smaller) one Share this post Link to post Share on other sites
jackherer 543 Posted August 1, 2020 30 minutes ago, jimbojim said: will look in to it in detail hope to find something wrong As Tom says there is nothing to look into! If you took it for an MOT the tester would probably tell you the bushes are fine despite them being the cause of your handling issue. 205 GTis are incredibly sensitive to worn wishbone bushes even before you add a Quaife or LSD which just makes it much worse. Share this post Link to post Share on other sites
Ozymandis 103 Posted August 1, 2020 Take off the wishbone and grip the front metalastic bush in a vice, wiggle it about and marvel at just how floppy its become. Find some genuine bushes they are firm and last well. Share this post Link to post Share on other sites
jimbojim 0 Posted August 1, 2020 i think from memory the wishbones are from another Peugeot 306 ( probably? to add to the width something that at the time were popular i will add a pic i am also in the process of ITB conversion and finding communicating between emerelad ECU end my leptop a bit of a daunting exspirince Share this post Link to post Share on other sites
welshpug 1,722 Posted August 1, 2020 309 that will be, same bushes as a 205. Share this post Link to post Share on other sites
jimbojim 0 Posted August 1, 2020 Would you consider on adjustable wishbone I have seen some on the net an after market once for around the£300 Share this post Link to post Share on other sites
welshpug 1,722 Posted August 2, 2020 no, good ones are closer to 450-500 Share this post Link to post Share on other sites
jimbojim 0 Posted August 2, 2020 https://www.ebay.co.uk/itm/283542950010 Anyone tried this Share this post Link to post Share on other sites
welshpug 1,722 Posted August 2, 2020 they dont fit with the standard anti roll bar and bend far more readily than a standard wishbone Share this post Link to post Share on other sites
jimbojim 0 Posted August 2, 2020 Ok thanks for your input I will probably just replace it with powerflex black bushes Share this post Link to post Share on other sites
Ozymandis 103 Posted August 2, 2020 23 hours ago, Ozymandis said: Find some genuine bushes they are firm and last well. https://www.205gtidrivers.com/forums/topic/153437-powerflex-polybushes/ Share this post Link to post Share on other sites
welshpug 1,722 Posted August 2, 2020 autodoc do sasic bushes which I have found to be decent, or Baker BM have also started making them. bit pointless if there is play in the non replaceable balljoint though. Share this post Link to post Share on other sites
Ozymandis 103 Posted August 2, 2020 I will give Sasic a go next time Welsh, their other stuff has been good. I just used their beam bearings on my wife's car and they were all Nadella full roller count. Share this post Link to post Share on other sites
jimbojim 0 Posted August 2, 2020 you are absolutely right but i hope it is just that LOL, i am also just finishing the wiring and have green light from the crank sensor with the aid of somewhat a batter missing wheel from pug1off which although wesent a fit but better then the one i had from emrelad,i now have an issue with communicating from my pc to the ecu,probably just a cable issue,yet to be seen,i have tried to figure out what are the two sensors just below no 4 on the inlet side, kind of bulge sensor could be engine knock sensor and oil pressure or oil temp,questions are1,do i need the knock sensor with the new ecu and 2 will a wide band lambda be preferably over narrow band,just looking for easy correct mapping realy Share this post Link to post Share on other sites
