A5H13Y81
Lambda sensor connections Bosch Motronic ecu
A5H13Y81
I have a 1993 PH2 and the previous owner had the Cat removed and the Lambda sensor wires... for the life of me I can't find where they have been cut??
has anyone got any idea how I can trace them back? I am only guessing they have been cut out as it was a diy job so I don't think the wires would have been removed fully from the loom.
I have no Idea if I am looking for wires running to fuse box or ecu or both? or at what point they would split from the loom.
Thanks for your help
DamirGTI
Take the battery out and see if there's any bits left around LH chassis leg , there's 4 wires for the O2 sensor and they go deep down the LH chassis leg till the floor base .
If there's none left , go by the wiring diagram :
A5H13Y81
Do you mean they run inside the chassis leg? Battery is out and I can see nothing running down the outside.
I have the diagram and have been trying to trace the wires for 2 days.
I have a loom out of a car. I'll take some pics for you.
No, They won't run inside the chassis leg.
There should be two plugs (blue & white possibly iirc) that come out of the engine ecu loom near where the gearbox bolts the block but as Damir said, they might have been tucked away elsewhere in the engine or gearbox area.
g.
red and white 2 pin plugs for the lambda sensor  one of the two uses a shielded wire from memory, like the crank sensor.
DamirGTI
306/405/605 , AX/ZX/XM/Xanita had red and white plugs on the O2 sensor .
205 1.9 DKZ has blue and black :
It took longer than I'd thought to find it and unfortunately the two plugs are missing. However, the wires leave the main harness in this smaller bundle, straight after the firewall. They make their way parallel with the brake lines, towards the coolant header tank, before dropping to the downpipe. There is a +12V and GND for the heater circuit, along with a black two core (red & green) shielded cable for the signal wires.
A5H13Y81
Amazing this is a great help! I’ll get the insulation tape off and see what I can find.
