markpw
Front ARB base model
markpw
I'm working through some simple suspension upgrades to my base model 205. To match the rear upgrade I'd like to try and source a larger front arb. The one fitted at the moment is 20mm and it seems that 22 and 23mm ones are available from more sporty models. Does anyone know where I can find one?  I don't really want to go down the route of fitting the Gti front subframe if I can help it.
Mark
calvinhorse
Pretty sure the 205 Xs had the thickest ARB, 22mm from memory, mine has one and it’s plenty
calvinhorse
The front bushes to match are rare as rocking horse teeth so if you find an ARB make sure you get the bushes
Ozymandis
N/A  Diesels are  23mm, also fitted to C15 vans, bushes are widely available, the blue ones.
If You fit genuine 309 base model TCA "mushroom bushes" to Your 205 TCA`s they make a big difference
https://www.ebay.co.uk/itm/GENUINE-PEUGEOT-CITROEN-FRONT-WISHBONE-BUSH-FITS-309-PART-NUMBER-352358-NEW/274299421407?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2060353.m2749.l2649
Dont get another brand, they are all s*it.
markpw
Thanks everybody. At least I know where to look now.
I'll try my luck in the wanted section.
