SootySport 23 Posted April 2, 2020 Not quite sure about this, I have a 1990 1.6gti with Be3 box so does this version share the engine oil with the gearbox or is it separate? Share this post Link to post Share on other sites
jackherer 543 Posted April 2, 2020 Only the very early 1.0, 1.1 and 1.4 'suitcase' engines shared engine and gearbox oil. All other models including all GTIs have separate gearbox oil. Share this post Link to post Share on other sites
SootySport 23 Posted April 2, 2020 Thank you for the quick answer Jack Share this post Link to post Share on other sites
SootySport 23 Posted April 4, 2020 Another question, does the gearbox share the oil with the final drive? Share this post Link to post Share on other sites
SootySport 23 Posted April 4, 2020 25 minutes ago, boldy205 said: Indeed It does. Thanks. Just confused as they have separate drain plugs. Share this post Link to post Share on other sites
jackherer 543 Posted April 4, 2020 The one on the final drive is a drain plug but the large bolt on the side is a level plug, i.e. when oil drains from there the gearbox is full of oil. Share this post Link to post Share on other sites
welshpug 1,622 Posted April 4, 2020 and to make your life much easier, I would fill it through the breather on the top, with the level plug on the side out and a tray under it to catch any drips. 1 Share this post Link to post Share on other sites
SootySport 23 Posted April 4, 2020 (edited) Yes, found all the plugs ok but what I drained out was red fluid, looks like ATF. Edited April 4, 2020 by SootySport Share this post Link to post Share on other sites
pugdamo 111 2 Cars Posted April 5, 2020 Probably is, I had an XS years ago with a slight crunch through 2nd when cold and a mate advised to put ATF in, was an old trick aparantly. I did it and it worked a treat, did loads of miles like that aswell. May not have been put in yours because of any faults, may have just been to make the gear change smoother or something. Share this post Link to post Share on other sites
welshpug 1,622 Posted April 5, 2020 I really would advise against anything but Total BV 75w80 or 75w oil. ATF probably would have been better than an EP oil for sure Share this post Link to post Share on other sites
DamirGTI 323 Posted April 5, 2020 (edited) Some people used to mix certain percentage of ATF with the gear oil .. to reduce synchro crunching and ease of engage as i've heard . Haven't tried myself , but remember my brother bought brand new Mazda 323 manual back in the early 90's , and despite it being specified for 75W-90 gear oil it came from the factory filled with the ATF ! ... and that car made it to the moon and back few times without any issue (+ 400T Km's) . Agreed , PSA gearboxes are proven best on 75W-80 Total oil . D Edited April 5, 2020 by DamirGTI Share this post Link to post Share on other sites
SootySport 23 Posted April 5, 2020 Now that’s surprised me that ATF works well but I would of thought longevity of the box would be compromised. Have some 75w/80 to fill the box with, So will find out if there are any underlying problems With the proper oil in. Share this post Link to post Share on other sites
dawning 11 Posted April 7, 2020 Put some comma oil in my Citroen as gsf don't do the Total any more and I'm sure it made it worse! Try and find the Total one if you can. Share this post Link to post Share on other sites
welshpug 1,622 Posted April 7, 2020 if it was EP type thats to be expected. gmf do total, lots on ebay too Share this post Link to post Share on other sites
