beyada 0 Posted April 23, 2019 My 205 XS needs new door hinge pins but cant identify the ones that are on the car. Attach some photos. Can anyone help and let me know where I can buy them. Thanks Share this post Link to post Share on other sites
Archie's mid life crisis 0 Posted April 23, 2019 Those look like the roll pin type. I recently did this job and I couldn't source original Peugeot replacements (part number 904430). Full hinge sets are available on fleabay, tho. I used standard 7 X 50 roll pins and they have worked fine apart from one hinge where the hinge bracket had worn excessively. For that one I welded up the bracket holes and re-drilled to the correct size. It's worth pointing out that the original Peugeot pins had a raised lip that engaged in the hinge bracket that made sure that the pin rotated in the body hinge only. If the hinge bracket holes are a bit worn you may find that the roll pin wants to turn in the bracket rather than the hinge. Share this post Link to post Share on other sites
beyada 0 Posted April 23, 2019 12 minutes ago, Archie's mid life crisis said: Those look like the roll pin type. I recently did this job and I couldn't source original Peugeot replacements (part number 904430). Full hinge sets are available on fleabay, tho. I used standard 7 X 50 roll pins and they have worked fine apart from one hinge where the hinge bracket had worn excessively. For that one I welded up the bracket holes and re-drilled to the correct size. It's worth pointing out that the original Peugeot pins had a raised lip that engaged in the hinge bracket that made sure that the pin rotated in the body hinge only. If the hinge bracket holes are a bit worn you may find that the roll pin wants to turn in the bracket rather than the hinge. Thanks for the reply really useful info. Share this post Link to post Share on other sites
farmer 328 1 Cars Posted April 24, 2019 I have original new pins about 30 in total Share this post Link to post Share on other sites
beyada 0 Posted April 24, 2019 46 minutes ago, farmer said: I have original new pins about 30 in total Hi farmer I'll need a set for the drivers and passenger side. Do you have the white plastic cap inserts as well? Share this post Link to post Share on other sites
farmer 328 1 Cars Posted April 24, 2019 Hi No, but you will get them from a dealer, part number = 6983 23 £5 per pin plus post ( post £1.10 ) Last Peugeot price was £5.86 per unit Share this post Link to post Share on other sites
Vezzy 0 1 Cars Posted September 1, 2019 Could I get two door pins please farmer? Share this post Link to post Share on other sites
Tom Fenton 1,564 Posted September 1, 2019 Just be warned that usually it’s the hinge worn, not the pin. Eg, you MAY fit new pins to find it’s no better. Share this post Link to post Share on other sites
Vezzy 0 1 Cars Posted September 1, 2019 (edited) Our pin is snapped in half!! Edited September 1, 2019 by Vezzy Share this post Link to post Share on other sites
Philpooma 30 Posted May 1, 2020 On 9/1/2019 at 7:59 PM, Tom Fenton said: Just be warned that usually it’s the hinge worn, not the pin. Eg, you MAY fit new pins to find it’s no better. Just picking up on an old post re hinge pins. I’m going to replace the hinge bolts on my car (not roll pin style), my question is are there bushes that insert into the metal hinge mounted on the A post? It looks like there is a bush there, but I cannot find any mention of hinge bushes anywhere. Share this post Link to post Share on other sites
