monty1991
Any advice to get more use of my tyres?
monty1991
Do i need more camber or stiffer suspension? im not getting use of the full Tyre mid corner.
both!
whats the spec of the car?
monty1991
ive bilisten shocks with unknown springs up front with eccentric topmounts
PhilNW
How long does it take to get the tyre in that state?
Presumably that is a front tyre what are the rears like?
What is that tyre and compound?
Edited by PhilNW
monty1991
3 min sprint is all it takes lol unsure of the compound i got the tyres cheap, rears are grand ive tonnes of grip at the back
PhilNW
Both front tyres like that?
It's quite a sharp line of definition between the good and bad,
possible tyre fault or have you had more than one tyre like that?
Edited by PhilNW
It is just shoving rubber across and the bit that is clean is the bit being used.
Typically on a competition 205 you want as much caster as you can achieve and much more negative camber than you can achieve with eccentric top mounts. An adjustable rose jointed lower arm is what is needed, just be careful with driveshaft lengths and joint plunge.
Crescent205
Typical of a part worn slick, its already been shaped/moulded by a different car running a completely different set up.
