kyepan
List of tools to rebuild be3 box
kyepan
Hi there,
Planning to strip and recondition a be3 with dad in the new year, he's done plenty of mini boxes, but we need to know what tools ( also preferred brand) that we'll need to complete the job properly. If anyone can help with a list of be very grateful.
Justin
Nothing that specialised really. A 12 point socket for the main shaft nut, it’s an odd size maybe 33mm but don’t buy one from that. I’ve an old Britool imperial socket I use that’s a good fit. A set of proper roll pin punches is useful for the selector fork pins.
  • Thanks 1
kyepan
Thanks both for the quick replies!
kyepan
Jack that link is brilliant, and entire guide! I'll have a good read through, sent it on to my Pa too.
28mm halfords 12pt 1/2" drive socket is what I bought.
pin punches and pullers as mentioned, as well as 11, 16 and 19mm sockets.
you'll need a low and standard range torque wrench, a vernier or digital caliper with depth gauge for the input shaft shim checking, give me a shout when you get to that bit as I have a selection of shims, though if you are re-using the original shaft you might be ok with the original shim.
And ThreeBond 1211 to seal it.
allanallen
And a hammer
No need to remove the pin on the main selector shaft it all comes out sliding it out, I can have one stripped in around 5 to 10 mins (Impact gun), longest bit is cleaning it up
