Harrybowling 1 Posted November 16, 2018 Hello just recently brought my first 205! Needs a lot of work but have been doing a lot of jobs thanks to all the info on this site! Hit a problem had a lot of water in the boot the other day and the boot lid glass is lose so think it’s coming in from there. Does the glass rely on the rubber trim or is there a sealer aplyed when fitting. Looking at refitting the glass myself but can’t find any info on the forums. Is this a hard job? Thanks Share this post Link to post Share on other sites
Tom Fenton 1,525 Posted November 16, 2018 The glass is sealed to the tailgate then the rubber trim pushes in to finish it. I’ve come across the same thing you have found before when the sealer has come away. You can probably bodge it up yourself with some PU sealer or otherwise it’s get a screen guy out to remove it and reseal it professionally. Share this post Link to post Share on other sites
Harrybowling 1 Posted November 16, 2018 2 hours ago, Tom Fenton said: The glass is sealed to the tailgate then the rubber trim pushes in to finish it. I’ve come across the same thing you have found before when the sealer has come away. You can probably bodge it up yourself with some PU sealer or otherwise it’s get a screen guy out to remove it and reseal it professionally. Thanks for that will try the first option as I will hopefully be getting the car sprayed next year. Share this post Link to post Share on other sites
