Greengti1
Rear trail arm fitting
Greengti1
Hi all,
just a quick question please.
i am rebuilding my rear beam, I have anew tube, bearing and trail arm tubes fitted and I am just about to fit the tail arms to the tube.
i inserted the trail arm tubes last nigh and they slid in well apart from the last cm or 2 ish.
Before i get my lump hammer out to seat the new shafts on the bearing I just wanted to check this is correct.
at this point I would rather ask a silly question then risk getting it wrong.
thanks very much for your help.
adam
Ozymandis
You mean the pivot shafts into the roller bearings I presume.
They should go in with a bit of fiddling, If your beating them in with a lump hammer then somethings not right.
Greengti1
Hi yes that's what I meant, thanks.
if a little fiddling is all that's required and not any force I am glad I asked!  I willl have another look later.
thanks
adam
I noticed this on the last 306 beam I built using the Peugeot rebuild bearing kits, the radius arm shaft goes tight through the bearings for the last 10-15mm.
I knocked the arm fully home when it first happened & then pulled it apart to check nothing had moved.
It was all as I'd built it up so I put it all back together & it's been fine on the car for over 20k since.
g
Greengti1
Hi
yes I went back to the garage I purchased it from and they said it was common on those tubes and bearing sets.  They recommended using a hammer (not to hard!) to locate it fully.
i will have a go at the weekend if I get time.
