mmt 14 Posted May 28, 2018 Hi guys, I am replacing a door. However the pins attaching the door to the car are somewhat rusty. I have soaked the pins in wd40. Do I hammer them Down and out? Are they reusable? (If I do not smash them). Thanks. Share this post Link to post Share on other sites
barneys66 120 1 Cars Posted May 28, 2018 For mine you could have done them either way - it's a Phase 1 though and I know there are different hinges for the later cars. Mine were stuck solid so I ended up taking the door off the hinge for better access (i.e. for a bigger hammer!) Share this post Link to post Share on other sites
mmt 14 Posted May 28, 2018 Thanks. Took another look to night. It is easier to change the hinge rather than hammering out the pins. What’s the difference between the series 1 - 1.5 and 2 doors? Are they all interchangeble? Share this post Link to post Share on other sites
jackherer 543 Posted May 28, 2018 Phase 1 doors are different in the internal lock pin area compared to phase 1.5 and phase 2. Phase 2 doors have different hinges to phase 1 and phase 1.5 but obviously these unbolt. Share this post Link to post Share on other sites
Tom Fenton 1,525 Posted May 28, 2018 Also I think the area the wiring loom passes through is different from the early to late doors that use the quick release plugs. Share this post Link to post Share on other sites
mmt 14 Posted May 29, 2018 (edited) Thanks. What is the “internal lock pin”? Is everything interchangeble? I Would take everything except wiring) from the old Bent door and install it into the new door. Edited May 29, 2018 by mmt Share this post Link to post Share on other sites
MattCPR 2 Posted May 29, 2018 If you manage to knock the pins out and need some new ones then give me a shout as I have some new ones you can have. Share this post Link to post Share on other sites
jackherer 543 Posted May 30, 2018 The 'internal lock pin' is the plastic rod at the top of the inside of the door that you pull up to unlock the door or push down to lock it. Share this post Link to post Share on other sites
mmt 14 Posted May 30, 2018 The internal lock pins are indeed different between My two doors. How do I get them out? And How do I get the surrounding plastic of? Share this post Link to post Share on other sites
mmt 14 Posted May 30, 2018 All fixed now. Everything including lock pin and surrounding plastic is interchangeble. Just made nydelig a Phase 1 door out of a phase 2 door. Thanks for pointers and help. Share this post Link to post Share on other sites
