MattCPR
Rear fog light switch
MattCPR
Is it normal for the rear fog light switch to lose its illumination when turned on?
Got no power going to the rear fog and none at the fuse box so I’m thinking switch?
The switch should light up brightly when switched on.  If it doesn't illuminate when switched on, I think that's an MOT failure.
You can swap the fog lamp and heated rear window switches around to test whether it's a switch problem or something else.
Davidsw
Check the rear passenger light cluster for corroded conectections . This is where they have a common link .
