blandy
Clutch recommendations
blandy
With my engine build underway and aiming for around 230bhp-ish
what clutches are people using?
Car will be a track car only so no road use currently using a Valeo mi16 set up
im using standard pull clutch, seems fine so far.
16v205
Posted (edited)
If your car is nasp, mine would be similar bhp. I was using a standard valeo mi16 clutch, it didn't slip.
I'm only swapping it out for another standard mi16 clutch as a few fingers have collapsed. It must have been 12 years old though.
Edited by 16v205
blandy
Posted (edited)
Yes forgot to mention it’s n/a so will be sub 200lbft torque I would  expect
welsh is there any benifit on push or pull? As I have the parts to run either
Edited by blandy
The standard valeo handles the torque fine, it just doesn't like high rpm downshifts. That's when the straps will self destruct.
I know Mike used a std for a while but like me is now on a Helix Paddle without any issues, mine's done around 6 season's now
blandy
Are you using the helix cover as well or just the pressure plate?
Using the set
