309Dimma
Removing A Xantia Es9J4 V6
309Dimma
I am removing a ES9J4 V6 from a 1999 Xantia to put in my 306. What do I need to get the engine to run? Engine, loom, ecu, key and the ring (antenna) around the ignition lock. Where does the loom from the ring go? Its 4 cables. I cant see as it disappears behind the dashboard. Is there a box or something I need?
Help wanted! :)
