erbs
Pump Question
erbs
I have removed the old fuel pump expecting some petrol to squirt out when I released the pipes from the pump but no pressure was released
I'm changing it because I feel the old pump may be a bit weak as it is the original Bosch pump (30 years old) is not up to the job.
Should it hold pressure when not running? I changed the regulator as it was faulty and now holding at 3 bar.
Edited by erbs
pressure will bleed off over time, you'll have negligible pressure after a day or two
erbs
ok, the pump has just arrived and its a lot thinner that the original pump,how is it supposed to stay in the housing?
i got the new bosch pump from mr auto
free photo upload
Edited by erbs
erbs
bugger, was hoping to fit this today.
pack it out with whatever you have to hand then, I used bicycle innertubes to get me mobile
erbs
is that a short term fix?
no rush to use my car, just like to know i can use it
should make a difference i hope or at least be more reliable and solve the hot start problem i was having
the new pump comes with the filter, do i still keep that on? or just use the original one with the pump housing? or even use both together as a bit of belt and braces.
Edited by erbs
erbs
with new pump in, all is well, starts on the button when hot and don't get the little hesitation when trying to sit at 30 or 40 mph
oil change and filter done, needs a wash then use the thing
erbs
for future reference the bosch pumps 0 580 314 075 are too big for the pump housing that member Allan makes by 3mm, so if you have a bosch, the housing will need to be made slightly bigger to suit the pump adapter
Walbro pumps fit fine
