dawning 11 Posted December 28, 2015 My wiper washer jets at the front have stopped working They worked for a minute when I swapped the pump over but tested both pumps and they are fine, and worked once or twice since. Also swapped the stalk on the steering column and the relay from another 205 and its still got the same problem. I think there must be a bad connection somewhere, has anyone had a similar experience? Share this post Link to post Share on other sites
Anthony 1,000 Posted December 28, 2015 Bad/corroded connection on the pump is very common. If the wipers move when you pull back on the stalk and you've tested the pump, then that's likely the issue 1 Share this post Link to post Share on other sites
Tom Fenton 1,526 Posted December 28, 2015 Cut the wiring back up into the loom until you get to good shiny copper wire. Then splice in new wiring back to the pump. Very common problem. 1 Share this post Link to post Share on other sites
jackherer 543 Posted December 28, 2015 Don't be surprised if you have to cut quite far back, sometimes it can be bad pretty much to the bulkhead. 1 Share this post Link to post Share on other sites
pugdamo 111 2 Cars Posted December 28, 2015 Is the earth for this not on the earth block on the front panel by the headlights? Iv had a few problems with those blocks over the years. 1 Share this post Link to post Share on other sites
dawning 11 Posted March 6, 2016 Forgot to update this.. @pugdamo you where right, Cleaned up the bolts holding the earth block and they worked pefectly. Thank you. Share this post Link to post Share on other sites
