Kane
4Wd Drivetrains/engines
Kane
Looking for some recommendations on strong full time 4wd engine and drivetrain packages available in the general market, i.e. not custom. I am however open to mating parts from different cars providing there isn't extensive machining involved.
Inline 4 engines are preferable although others considered. Decent aftermarket parts availability for boosted applications would be beneficial. Oh and as with everything affordability comes high on the list.
This will not being going into a 205, just doing a little research really.
evo to xu has been done.
xu blocks are still commonly used in rallycross supercars running a restricted 550 bhp, not certain which transmissions but I believe Sadev and xtrac are used by many.
rallyeash
Subaru. But 6 speed stuff.
oh, are you not looking to use a pug shell or engine?
Kane
No it won't be going into a pug shell although i am not against using an xu if it proves to be a suitable option.
I have looked into the 4g63t engines with evo running gear and although they do tick the right boxes whole cars do retain reasonable value. Accident damaged or buying parts separately may help reduce overall costs however.
I've briefly looked at the subaru flat 4's although packaging may be difficult.
rallyeash
Packaging?
Kane
Getting it to fit! Saying that the evo engine isn't too compact either.
Just for info the car, or likely silhouette that this brainwave relates to is a round nose mini.
ahhh you've been watching project Binky then :D
Kane
Haha I've been following that one on and off yeah. Doubt my finished product will look as good as that pairs scrap pile but you can always hope.
aldworth33
Ew engine with freelander gearbox? might be bulky in a mini, you thought about 2 bike engines?
freelander and xu might be possible, they did use a dw12 but I'm not sure if it's the same bellhousing pattern.
rallyeash
Can you retain the hill desent if you choose to use freelander please ????
Kane
I think one engine is going to be complicated enough never mind throwing a second into the mix. Plus two engines and everything else to go with them is likely to be mucho expensivo!
Sounds like a possibility. From the little I've read up on before I'm guessing it would be relatively straightforward to swap over the bellhousings? Quite a good range of gearing options also available no? Before i go hunting how does the freelander drivetrain cope with more power pushed through it?
The one thing that comes to mind which could be problematic is the front mounted intake. Modifying the bulkhead would allow the engine to be shifted back to help clearances up front but driveshaft angles could end up being way out. Would shortening the intake have a dramatic effect on performance in a boosted application?
Not looked at the audi but I'm assuming being 20v that mothers going to be wide!
allye
Are you really sure you're up to doing this sort of massively custom fabrication task (as no matter what you choose it's going to take a huge amount of fab work and jigging)
20v is a 4cylinder and quite compact. There is a chap on retro rides who has fitted one, albeit FWD version, to a 205. They are easily tunable to 250bhp and would be my choice. Haldex (spelling?) 4WD system too.
Kane
To be honest at this moment in time no i wouldn't say I'm completely ready to take on such a task but as i mentioned in my original post I'm just doing a little research. I do fully intend on attempting a modern engine conversion into the car although the extent of how far i go is yet to be confirmed.
I'm approaching this as more of an engineering challenge which has no deadline so if it takes years to get myself into a position where I'm confident enough to carry out the fabrication required then thats what it will take. The last thing I'm going to do is cobble together something that is unsafe and unusable.
Ah i assumed it was a 5 cylinder, I'll see if i can find the 205 on retrorides for a nosey. Cheers
Biggles
Easily tunable to a duck sight more than 250 esp if you get the right one. 600 with deep pockets.
Nice engine. I have nearly 220k miles on one in my Octavia (also with the Haldex 4wd system).
If you were going to the hassle and expense of 4WD, why on earth would you choose Haldex?
Kane
Ah i missed that, only looking for full time 4wd so the haldex type setup is out. Thanks anyway
Kane
Appears that the freelander also operates a haldex setup so that's that one out as well unfortunately.
all of them??
Biggles
20v VW motor came in various Audis too so full time 4wd not an issue - just use the Audi transmission.
What are you planning on doing with the car ? The Haldex system is very configurable - much over 250 bhp and the std controller starts to struggle as it only feeds power to the rear when slip is detected. Aftermarket controllers look at throttle position too so you can have 2wd when cruising (when you don't need 4wd) but nail the throttle and it immediately goes to 4wd without waiting for slip to be detected.
A lad I know is in the throes of building a Mini using a Honda engine of some description mated to a 4wd gearbox and rear diff from (I think) a HRV.
Kane
From what I've found so far the dw12 equipped freelanders all operate on the haldex 3rd gen coupler yes.
For now it'll be for track use only. The reason for 4wd is to cope with a setup where 'usable' fwd power is exceeded so if there are issues arising from a haldex setup over 250bhp then it would be easier and simpler to stick with a fwd setup.
I've briefly read up on fixes for haldex type couplers to produce an effective full time 4wd setup but if I'm not restricted to using this system it seems a step in the wrong direction choosing it in the first place.
Rippthrough
Don't use Freelander running gear unless you like replacing....well, all of it.
Seems like a strange project to start if you're not happy with doing custom setups to start with though (Having done a 4wd drivetrain with a new Mini shell over the top myself), even just shuffling the whole lot inside another shell takes some work and you generally end up with something handling like a dog unless you start to move mountings and then you need custom bits anyway.
Edited by Rippthrough
