arwel
Mi16 Wont Start From Cold
arwel
Hi guys. back again with another problem now. When the car has been left over night it refuses to start unless I persuade it with some easy start. Once its ran it'll start every time without fail. I am looking at an ecu temp sensor issue or something else?
The ECU temp sensor is definitely the first thing I'd check given the fault you describe, you can see if it is OK or not with a multimeter.
S@m
That would be my first port of call aswell, try unplugging it to see if it makes a difference, but they are usually less than a tenner anyway.
arwel
Thanks guys. I'll have a look at it at the weekend.
