theoilburner 7 Posted July 27, 2015 (edited) Sorry for all the stoopid questions, not familiar with the 205 and doing some rewiring....found this empty box, is something missing?? And this connector which is not connected to anything??? Thanks Edited July 27, 2015 by theoilburner Share this post Link to post Share on other sites
welshpug 1,626 Posted July 27, 2015 a relay box and a diagnostic connector of some kind IIRC Share this post Link to post Share on other sites
Ryan 99 Posted July 27, 2015 The box normally contains the relays for the dim/dip headlamps, and the horn compressor if it's a 1.9. I think the connector is something to do with ABS, and not used if you don't have it. Share this post Link to post Share on other sites
hoodygoodwood 70 3 Cars Posted July 27, 2015 On my 309 GTi I have 3 relays in the black plastic box . I also have the unknown connector close to the expansion tank as well as 2 further unused wires behind the nearside headlamp , I have assumed they are aircon/ABS and have removed them all back to the fuse box and rewrapped the loom as I have put this car through a bit of a weight loss programme . Share this post Link to post Share on other sites
theoilburner 7 Posted July 28, 2015 Cheers, the dim/dip has been removed hence no relays then, also mines was originally a 1.6 so no horn relay. Doesn't look like there was ever anything in there. Share this post Link to post Share on other sites
ade 4wd 11 Posted July 28, 2015 The white two pin connector is for the optional ABS. Share this post Link to post Share on other sites
