erbs 42 1 Cars Posted June 11, 2015 Had an easy ride so far so it was about due for failing took the front bumper off to replace the irons, corner bar etc all back together looking swish but now my driving lights don't work tested the power and was up and down on the meter and i tested them direct to the battery and they work confooosed me this has? any ideas? Share this post Link to post Share on other sites
welshpug 1,737 Posted June 11, 2015 grubby connections on the two two pin yellow plugs is most likely, I cut mine back to fresh wire and fitted new superseal plugs. could be the earth for the circuit, though if all else is in order thats unlikely Share this post Link to post Share on other sites
erbs 42 1 Cars Posted June 11, 2015 (edited) ok so went back and tested and no power coming out of both yellow plugs. where else should i look? i checked the fuse and is fine also in the fuse box i have no relays in the first part of the board, from the left and second one in? its never had any relays in there but the driving lights still worked before Edited June 11, 2015 by erbs Share this post Link to post Share on other sites
erbs 42 1 Cars Posted June 12, 2015 Found the problem...............thanks for your input Share this post Link to post Share on other sites
rikky 37 Posted June 12, 2015 Probably just manky connectors like you said. Mine were the same Share this post Link to post Share on other sites
erbs 42 1 Cars Posted June 12, 2015 Loose connection on the alternator Share this post Link to post Share on other sites
