jamie_1992
Will They Fit
jamie_1992
well basically im looking to get some new wheels and i like the speedline sl434 i have read lots about them fitting with 309 running gear on the front but not the rear, will they be too wide with a 309 rear beam on?
im also running brembo 4 pots on the front a currently using 20mm spacers will fitting these wheels mean i can loose the spacers?
heres a link to what im looking at http://www.revolution247.com/catalogue/shop-by-category-alloy-wheels-speedline/speedline---peugeot-sport-type-sl434-alloy-wheel-white
allye
yep they go over 406 brembos just about. Para has done it.
jamie_1992
thanks well at least the front will be ok.
dose anyone know if they will fit with a 309 beam?
allye
They will, however it varies from car to car, some scrub slightly and "self trim" the arch, some just get away with it.
jamie_1992
well looks like il just have to give it a go and hope for the best (watch this space)
jamie_1992
well these turned up today and i can confirm they don't fit over the front brakes it looks like they will need at least a 10mm spacer, which is rather annoying as i wanted to do away with the spacers
jamie_1992
and they also dont fit on the back with a 309 beam. both arch trims have been ripped off
They do fit but you need to trim the return lip on the plastic arch.
