iwallers
Temp And Oil Gauge Stopped Working
iwallers
Hi,
I have a phase 1.5 and after a few months off the road I got it going today, the temp and gauge above has stopped working, the light on the temp gauge comes on when starting and fan working fine
Thanks in advance
dcc
search for brown multiplug
iwallers
Where is it located, and what do I do with it
scbond
He meant search the forum about it...you'll find everything you need about it.
Edited by scbond
iwallers
Thank you
iwallers
Found the location of the engine one, where will I find the dash one
Will I need to take dash out?
Where is the likely issues dash or engine
scbond
Highly unlikely to be the one under the dash inless it's been fiddled with before. The one in the engine bay is the usual culprit...best solution is to cut it out and wire in a new plug or remove the need for one by soldering.
iwallers
Tried and checked brown plug all ok, any ideas?
Could it be the gauges?
theoilburner
When you say you checked the brown plug what did you actually do?
dcc
to check the gauges / wiring - earth the wiring to the engine block - if the gauges read full you have a fault between there and the engine block (i.e. sensor fault or connection to sensor)
I initially had a fault with my car showing a drop of oil pressure at speeds in excess of 50mph, turns out it was wind blowing on the wiring spade connector and it wasn't making a good contact. a bit of a nip up on the spade with a pliers, and job done!
for both sensors to stop working I would imagine it is a wiring fault at the multiplug in the engine bay.
iwallers
Checked each wire, connections and fixed one red wire which appeared broken
dcc
have you done what I have said?
iwallers
No dcc, not yet, I'm utter rubbish with electrics and un sure which block to earth, engine block or inside car.
Sorry for sounding dumb but pants with these things
Pull the wiring spade off the sensor end, or undo the nut on the oil temp sensor in the sump. Touch the end of the wire to something metal and clean on the engine, a bolt head for example.
Get a helper to watch the gauge on the dash ( ignition on)
If all the wiring is ok the gauge should read maximum when you touch the wiring to earth. If it DOES then it could be the sensor at fault. If it DOES NOT then it's a wiring fault between the sensor and dash.
iwallers
Thanks alot for advice
