PeterGriffin
Poorly Considered Drag Challenge?
PeterGriffin
After some facebook bragging I've challenged my brother to a drag race at the aerodrome. He has a mint 1989 Beemer E30 325i.
I'm almost certain it's bog standard, no surprises or tweaks lurking, but it is in very good nick. I have Mi16 with fast road cam on the inlet, and a 1.6FD into a 1.9 box. I think it could breathe a little better but I won't have time to pick an exhaust...!
The more I think about it, he'll be a dot in the mirror. Opinions? :wub:
calvinhorse
If his is standard I recon you'll wipe the floor with him :)
Top speed he will def win tho!
I keep thinking this, my stripped out 165 bhp 8v 309 vs my girlfriends Citroen C4 180bhp vts! See who wears the trousers!
allanallen
Guesstimate times.....
E30 low 16s
205mi low 14s
pip470
I think 15 for the pug and 16 for the beemer . Good luck
An E30 325 is very close to a 1.9 8v 205 GTI so an Mi16 should be considerably faster.
PeterGriffin
I think the gearbox will have me up to 70 or 80 in not time and it'll be too late after that. I only get around 115mph with that gearbox combo but it's worth it.
I'm back to being keen again...
should get a lot more than 115 from that gearbox with an mi16
Roon
With total ease even of you fluff up the start.
S@m
The mi16 in my 306 used to easily beat 325's and that was with an S16 gearbox, so with a 1.6 box and in a 205 it should be a walk over.
pugdamo
im sure you will be ok,less weight to drag off the line and similar power,the only place he's got you is with the torque i guess his is a fair bit more than yours but you've got short ratio's and his are going to be pretty long so in a sprint should go your way.Go get him :)
pugdamo
Did this happen?Hope it went well for you :)
benny205mi16
Same as above,
Did this ever happen?
Was hoping for a video!
