davey205
Clifford Eagle 1 Remote Control Range /lowering Sensitivity
davey205
Is there anyway to change the Clifford remote to a newer more sensitive setup or are they not backwards compatible?
I am getting lots of false positives probably from cats or birds landing on the car and was wondering if I could buy a more sensitive remote so I can look out the window and cancel a false positive or if this isn't possible is there a way to dial down the sensitivity slightly?
Edited by davey205
2-Pugs
Have you tried CliffNet wizard? (Assuming you can connect to the Eagle system with it). There might be an option in there to adjust sensitivity. It's been a while since I've used it but it's certainly worth a look.
